Continuing to the next line
Does anyone know how to continue a lookup or lookdown table to the next line? When it starts to get too long in length, I press enter and continue the table on the next line, but at compile time, it says it expects an expression term on the first line and will not run.
"You do not really understand something unless you can explain it to your grandmother."
-Lucky[size=-1][/size]
What I would like to do is stick a lookup table into a VAR section without having to copy those values from the DAT section using code. My application is very tight on RAM/code space so it would be ideal to do something like this:
I would like to do this because I would like to pass the address of the lookup table to an assembly routine. I'm limited on space in the assembly routine too so I can't stick it there...
Any ideas?
-Jack
Why not just lay your tables out like this:
