dealing with rotations per minute of a continuous rotation servo... — Parallax Forums
IIIA.2IIIA.2 Posts: 2
edited 2010-04-01 16:14 in BASIC Stamp
Hi, I'm taking robotics as an elective and i think you may categorize me as a 'beginner.' Well, right now my class is dealing with the motor's RPM. Thus, my question is, how can I speculate the RPM of the continuous rotation servo when it is assigned a particular motor speed???
Here is the code sample the teacher handed to me;
' {$STAMP BS2}
' {$PBASIC 2.5}
loopcount var Word
motor_speed var word
loopcount = 150
motor_speed = 1200
DEBUG "Motor On", CR
DO WHILE loopcount <150
Pulsout 13, motor_speed
PAUSE 20
Loopcount = loopcount + 1
LOOP
DEBUG "All done."
END
Thanks [noparse]:)[/noparse]
    edited 2010-03-31 21:09
    Empirical observation, Watson! It's all approximate, and will vary based on your particular your setup, servo, load & battery voltage. With fresh batteries, test several different pulsouts and count revolutions per minute and make a lookup chart. It will be roughly repeatable, but RPM will slow down as your load increases or your batteries poop out. For more consistent results, use rechargeable batteries, NiMH or LiPo.
  • IIIA.2IIIA.2 Posts: 2
    edited 2010-03-31 22:20
    Thank you. [noparse]:)[/noparse]
  • silverbacksilverback Posts: 40
    edited 2010-04-01 00:20
    IIIA.2 said...
    ' {$STAMP BS2}
    ' {$PBASIC 2.5}
    loopcount var Word
    loopcount = 150
    motor_speed = 1200
    PAUSE 20
    LOOP
    DEBUG "All done."
    END
    If you are using a parallax CRServo your pulsout range is 650 to 850
    If you convince yourself that something is impossible before you even try; you are sure to prove yourself right.
    edited 2010-04-01 15:50
    Also the motor won't rotate because of the value of loopcount.
    - Stephen
    Franklin said...
    HA! you're right! So to answer your question..... RPM = 0
    "puff"...... Smile, there went another one.
