time control on image capture(Linescan sensor)
Does any know what code you need to write in order to control the time interval between each image capture? Right now, I am using the code written on the manual such that the camera is only triggered when the lighting condition is dramatically changes, say I move the LED position. However, I want the camera to snap a picture every 2 second regardless of external environment. Has anyone done this before?
PS: I didn't OR XTRIG with the ACRBIN.
cheers
cheers
thanks, I've tried to use 'PAUSE 100' command in the loop, so every 100ms, it should execute the ACRBIN command but it didn't. Here's the code I wrote:
lft_edge VAR Byte
rgt_edge VAR Byte
max_dia VAR Byte
OWOUT owio, 1, [noparse][[/noparse]SETEXP, 30]
OWOUT owio, 0, [noparse][[/noparse]SETBIN, 128, 10, FIXED|LEVEL]
DO
PAUSE 100
OWOUT owio, 0, [noparse][[/noparse]"<", ACQBIN, FNDNXT|FWD|BRTEDG]
OWOUT owio, 0, [noparse][[/noparse]FNDNXT|BKWD|BRTEDG, ">"]
GOSUB Ready
OWOUT owio, 0, [noparse][[/noparse]DUMPADR, RESULTS + 5]
OWIN owio, 2, [noparse][[/noparse]lft_edge, rgt_edge]
IF (rgt_edge) THEN
max_dia = rgt_edge - lft_edge + 1 MIN max_dia
ELSEIF (max_dia) THEN
DEBUG "Bagel diameter: ", DEC max_dia, CR
max_dia = 0
ENDIF
DEBUG "exposure interval: ", DEC 100, CR
LOOP[noparse][[/noparse]code]
But the debug window gives me result of
100
100
Bagel diameter: 50
100
100
100
100
100
Bagel diameter:180
100
Bagel diameter: 100
These diameter value shows up only when I change the angle or move the position of my LED, not controlled by the software I wrote...
thanks
If you want it to send the value of every non-zero width it sees, do this:
