Propellor USB Servo Controller
Why does this servo controller have such a hard time when I use servo cable extensions?· If I connect the servo directly to the board it works fine but if I use an extension cable the servo twitches erratically.· The old discontinued servo controller would work fine with or without the extension cable.
Any ideas how I can get around this issue?· Thanks [noparse]:)[/noparse]
Eugene
Post Edited (OneCoolCat) : 3/31/2010 12:24:56 AM GMT
Eugene
Did some testing (All with Propeller USB Servo controller)
(All Extensions were tested with at least 4 different PWM extension cables; some futaba some hitec standard)
(All configurations tested with at least 5 futaba s3305's and 2 hitec HS-5485)
Futaba S3305 No extension - Works
Futaba S3305 With short extension - Works with a little chatter (Some servos better than others; no consistency)
Futaba S3305 With medium extension works with significant chatter; barely controllable
Futaba S3305 with Long extension - wont even try to turn on; as if it werent even getting a pulse.
Hitec HS-5485HB Works in ALL cases with no chatter.
Testing with Astro Flight Inc. Servo Tester
Futaba S3305 works with ALL extension lengths in all cases with no chatter
HS-5485HB works with ALL extension lengths in all cases with no chatter
I hope this provides some insight to someone who knows more about this board than i do [noparse]:)[/noparse]
Its worth noting that the Futaba S3305's are standard analog servos and the HS-5485HB's are from HiTec's "Standard Digital" line.
Additionally, all testing was done using USB access via the PSCI application provided by parallax; not serial from a separate micro controller.
Some testing was done briefly using my own application with the baud mode at 38400 (also via USB) but no significant differences showed up so I didnt bother testing extensively.
Hopefully later today I will get a chance to test via Microcontroller -> Serial just to get all the info up here in hopes of finding a solution [noparse]:)[/noparse]
Post Edited (MitchT) : 3/31/2010 10:41:03 AM GMT
Parallax Engineering
Post Edited (OneCoolCat) : 3/31/2010 6:21:45 PM GMT
·http://forums.parallax.com/showthread.php?p=862005
Jim
Are you working on the same project i am? :P
We also tested the S5301's (forgot to post) and found no issues at any length.
As for bidirectional autoswitching I REALLY want to use this with HiTec HMI protocol to read servo position as position capture - and we are slowly cycling out to HiTec stuff anyway; BUUUUT i'm hoping this temporary solution works out too [noparse]:)[/noparse]
Thanks for fast replies!
Where are you physically? We have a ton. PM me [noparse]:)[/noparse]
(Bay area california here)
This is to one that gave me the most trouble:
JR DS8711 Digital Servo
And this fixed it:
Jim
Mitch-T:· I'm working on a robotic arm to handle test samples.··
Ah [noparse]:)[/noparse]
Not quite heh
www.xdtech.net/p/gantry.jpg
www.morav.net
Anyway - I've recently been swapping out the S5301's (the big servos we use in the legs on these guys) with the HSR-5990TG's - I find that the fact that they are digital simply gives more stability and less chatter under high load. However the S5301's if supported correctly or tensioned for use in an arm (with a spring or bungee) would probably do better because they are far stiffer and basically dont need power to hold certain amounts of weight at strange angles. Not so good for smooth moving robot though [noparse]:)[/noparse]
