Ethernet access from Propeller
I'm working on a remote data logger and I believe Gadget Gangster's Propeller platform with SD card and a real-time clock would be a good fit. I'd like to retrieve the data blocks (every week or two - maybe a couple of MBytes at the most) over the internet.
Any recommendations for an Ethernet module for use with this platform? Anybody actually done this?
You could use the Gadget Gangster Propeller Platform (the non-sd version) and the Brilldea PropNET PCB/Kit. You can see details about the PCB here: www.brilldea.com/product_PropNET.html Very soon (this week?) Nick and I will be posted a PropNET kit on the Gadget Gangster web site. There are various W5100 drivers that others have created, especially an SPI driver from the Hydra EtherX card, but I am also working on a generic driver for SPI as well as indirect/parallel. I have been posting my work in progress code in another thread. Furthermore, Parallax is working on a Propeller Web Server product which I am collaborating with on the software side. The PropNET is a precursor and a development platform for the Propeller Web Server.
Another option would be to use the Propeller Platform SD version and then wire up a proto board with the Microchip ENxxxx IC that many people have used including the y-box. I believe the user Harrison has had some great success writing software and a TCP stack for this IC.
Timothy D. Swieter, E.I.
www.brilldea.com - Prop Blade, LED Painter, RGB LEDs, 3.0" 16:9 LCD Composite video display, eProto for SunSPOT, PropNET, PolkaDOT-51
www.tdswieter.com
