Ping))) Response Time
[noparse][[/noparse]Reposting from Robotics forum as this seems a more appropriate forum for this question]
based on this set of numbers from the Ping ))) datasheet:
•Input Trigger: positive TTL pulse, 2 µs minimum, 5 µs typical
•Echo Pulse: positive TTL pulse, 115 µs to 18.5 ms
•Echo Hold-off: 750 µs from fall of trigger pulse
•Burst Frequency: 40 kHz for 200 µs
Is it resonable to assume that the max response time for the Ping ))) is 18.5 ms, or should one buffer this with the Input Trigger and Echo Hold-off times as well?
thanks much.
thanks much.
You can delete your other post by clicking the red x in the upper left hand corner, as long as nobody has replied to it.
Powered by enthusiasm
Parallax Engineering
