is ip free service the same as having a domain name? — Parallax Forums
P!-RoP!-Ro Posts: 1,189
edited 2010-04-01 15:08 in General Discussion
I talked about it to a tech guy a while back saying I couldn't see the web service from an old computer running Apache outside of my own network and he told me I needed to buy a domain name to get past my internet provider (Cable One). Is having a domain name really all that different from using free services like no-ip (which doesn't work)?
Pi aren't squared, pi r round!
    edited 2010-03-30 12:55
    The domain name isn't really the issue.
    The real problem happens when the request is directed at your IP address assigned to your cable modem or dsl adapter.
    Depending on your configuration, you need to "forward" the incoming requests to stations on your network.
    Generally, most home routers have a "forwarding" function in them that simply needs to be activated.
    Let's say that your external IP address (the one that everyone could see) is 24.123.11.150
    and that your workstation has been given 192.168.1.100 from your router.
    Now if it is a web server you are running on your workstation it would use ports 80 and 81. (generally, but see below)
    A request from the outside world is made to 24.123.11.150 to retrieve a webpage.
    That request goes to your router, which if forwarding is setup would have a truth table which says that
    any request made to 80 or 81 should be forwarded to workstation on 192.168.1.100
    At that point the packet is set to your internal machine and it answers the request to display a page.
    [noparse][[/noparse]Some problems that might need to be overcome]
    Some internet providers turn off lower ports 1-100 (or so) and claim they are doing this for your safety. (NOT)
    The truth is that a lot internet providers aren't really keen on your running a server on their network as it
    creates additional traffic. (Not much really) Some have even gone as far as stating in their contract that
    you are not allowed to do this. (check) Hogwash really...
    If you find that standard ports are blocked, simply set your webserver software to use 8080 and 8081 or
    grab a couple higher numbers out of the air and set your router to "forward" requests made to those ports
    to your workstation. The only change on the outside world is that you have to add a port number to the
    address. http://24.123.11.150 becomes http://24.123.11.150:8080
    BTW you can find out what your external address is by going to http://www.whatismyip.com
    [noparse][[/noparse]Notice how I haven't mentioned a domain name yet?]
    Now if you want to connect a domain name, you "could" go to somewhere like gkg.net and purchase
    a name, by using the "free parking" that comes with your domain, simply forward requests from
    http://www.whateverdomainyouthoughtwascool.com to http://24.123.11.150:8080
    If you want to use a free sevice like dynamic dns, simply download their client software, pick a name (or subdomain)
    from their list. Their software does all the work of keeping track of your current external IP and directing
    the traffic toward it. The catch is that you will still need to do the prep work to your router as listed above.
    Clear as mud?
    OBC
    Are you Propeller Powered? PropellerPowered.com
    Visit the: PROPELLERPOWERED SIG forum kindly hosted by Savage Circuits.
  • P!-RoP!-Ro Posts: 1,189
    edited 2010-03-30 16:57
    I don't understand how to prepare a router like you talked about but I'll research it on the web. Right now I'm looking for a suitable Linux software for the old computer so I can start doing what you said but I'm not having much luck...
    edited 2010-03-30 17:43
    What router do you have? Brand and Model number.
    Also, I've honestly found it easier to use a simple windows web server for this type of project.
    (yes, a linux guy actually said that!) You won't have to deal with Apache configuration (an artform onto itself)
    while learning how to get all the other stuff nailed down.
    Granted, the security of a Windows box isn't linux, but..... [noparse]:)[/noparse]
    OBC
  • SRLMSRLM Posts: 5,045
    edited 2010-03-30 20:03
    Tomcat is another popular (free) server package.
    Powered by enthusiasm
    edited 2010-03-30 20:30
    I'm burning a Debian disc now but I'm not sure if it'll work. It's only a Pentium II 233mhz computer. It has dsl on it but I can't figure out how to run apache with it which is why I'm trying Debian.
    @OBC--it's connected to an Arris modem. I guess once I get apache to work I'll move on to everything else...I just wish I never took win98 off that machine.
    edited 2010-04-01 02:50
    I must say OBC your advice worked after all. 2 days·working on it I got webserver puppy running apache to connect to the internet (I checked it through my phone internet service). I don't have a website on it but the test files show up well at 174.126.89.46:8080--assuming the computer is on. Thanks a lot for the support! I've been trying on that machine since last year before you came along.
    Pi aren't squared, pi are round. Cornbread are squared!
    edited 2010-04-01 13:43
    Does it work from the outside world? Not just inside your network?
    OBC
    It's visible through the Verizon network, so I'd assume yes. Later when I get an actual webpage on it I'll leave it running during the day. Using no-ip it's address is pi-d.zapto.org, but I'm irritated that it doesn't show different pages as pi-d.zapto.org/page, so refreshing it goes back to the beginning.
