If a code error is a bug, what is a documentation error?
·I spent all day Sunday ripping my old BOE Bot apart and mounting the bread board from my PE kit to the BOE Bot chassis.·Then a CAREFULLY wired the circuit shown in the Propeller Boe-Bot Schematic.spin file.· Each connection was double and triple checked like this thing was going to Mars!· Next I loaded the code into the·EPROM and ....the darn thing ran backwards and was completely unresponsive.· Servos worked (continuously backward) and my scope showed a good signal to the IR LEDS.
·Checked the wiring again.·Yep, I did what the diagram showed.· Aw the heck with it, let's go to bed.....
Monday night I looked and the diagram from the PE Kit labs (p.148·for an IR sensor) and found the error.··Signal and ground are reversed....Hmm that would have an impact....
So I rewired the IR sensor·like the PE Kit shows, and IT WORKS!!!
So...FYI and correct me if I'm wrong, attached is the corrected schematic.
Regards
Steve
Recent Project Videos:
http://www.youtube.com/watch?v=jI79Xsm_Kyk&feature=channel_page
Cool Cars:
http://www.youtube.com/watch?v=SLnPhYKZCqo&feature=channel_page
http://www.youtube.com/watch?v=d2xGkYN4v7g&feature=channel_page
So, what's the reason for a documentation problem?
I'd say there are several possibilities and I'd suggest the follwoing names for it:
confusor - this is the case when the author simply was confused or wants to confuse with the documentation CONFUsion errOR -> CONFUSOR
mixor - the author already had the next project in mind when writing documentation and mixed things up MIXup errOR
boror - most likely ... what happens if the boss says : OK, work is done, now do the documentation! Developer: Oh nooooo .... this leads to BORedom errORs
;o)
Nathan
"Free as in freedom, beer gratefully accepted though."
8x8 color 80 Column NTSC Text Object
Safety Tip: Life is as good as YOU think it is!
