A question about servo power draw
I am posting this question in Propeller forum because the project I am working on is using a propeller.
If this should be in the Sandbox section, I apologize [noparse]:([/noparse]
TLDR below wall of text.
The project I am working on requires 11 servos and 11 RC time inputs. Each servo has its own
potentiometer, and a change in the potentiometer's rotation corresponds to a proportional change
in the servo's rotation. I have a wall power adapter which I will use to power the propeller and its
RC time circuits, and I have a second wall adapter which I am planning on using to drive the servos.
In research for this project, I could not find much explicit or straightforward data regarding the current
draw of servos. As I understand it, their current draw is rather variable and is related to the load and
movement status of the servo. The servos are rated to operate with 3.5-7.5 volts. The adapter I
plan to use to drive them with outputs 5 volts at 1 amp. Should I be running into any current issues?
Or is there not any way to tell?
TLDR: Will a 5 volt/1 amp power supply be enough to power 11 servos?
I will post updates on my project as I have time. And as a hint to what it is I am building...
it is quite handy [noparse]:D[/noparse]
Timing on movement can help. If you don't have much holding torque then stagger the others so you are only moving one at a time or as few as possible at once.
Signature space for rent!
Send $1 to CannibalRobotics.com.
I'm thinking a hacked PC power supply could do that. They need a dummy load, and I've used a stripped down motherboard (no ram no CPU) as a dummy load. Or power resistors on the 12V and 5V lines. Then you would have a high amp power supply.
Alternatively, four nicads and keep them topped up with a constant charge (that you turn off if over charged) and monitor for over and undervoltage and shut it off if one cell goes flat etc.
www.smarthome.viviti.com/propeller
Most of the servos will be under a load during operation. The rest will be under a light load during operation.
Knowing that each servo could draw up to 1 amp (although unlikely to happen), and finding a single 11 amp
power supply would be relatively difficult, would it be overly shameful to use multiple 3 amp power supplies?
