PASM-Counter Issue — Parallax Forums
PASM-Counter Issue
WurlitzerWurlitzer Posts: 237
edited 2010-03-30 12:10 in Propeller 1
I have set Cntr A's register to:
CntrA_Cfg               long    %0_01000_000_00000000_000000_000_01111
mov     ctra, CntrA_Cfg
(note I have played with the Pin# in case I have screwed up on pin assignment)
My intent is to have the counter reset to zero and stopped when P15 (starting from P0) goes below %50 Vcc.
I have an inductor discharging a capacitor on P15 and the waveform is perfect. It slopes from 3.0 volts to 0 volts with every event. (each event is ~~50 micro seconds) The 50% level looks like it is hit 25 micro seconds after the counter is reset.
The decay time from 3.0 volts to 50% lengthens as the inductance increases.
However, the value returned from the counter A is always the same regardless of slope or if P15 is just held high or held low. Right now it is always 4015.
It appears that it is just returning a value based upon when I look at it in code and not a function of P15.
If I change the interval at which I reset then copy the counter value, that value does change but always remains the same regardless of the slope on P15
My question is given the counter register configuration above should I be able to vary the counter value base on the time required to drop below 50% of Vcc?
I use the following to capture the value of the counter after what "SHOULD" be sufficient time for the counter to stop counting.
mov     InputCount, phsa
  • KyeKye Posts: 2,200
    edited 2010-03-29 17:30
    So... I would double check all you pin mask and such and make sure everything is correct. What you are doing should work.
    You just need to clear the phsa counter with a mov phsa, #0 instruction and then wait for it to accumulate.
    Try studying the below code.
    Nyamekye,
  • WurlitzerWurlitzer Posts: 237
    edited 2010-03-29 17:50
    Thanks Kye!
    This is how the dira and ctra are set:
    EDIT: The 4 "or" statements are the only settings for dira and it is not addressed elsewhere in the program so P15 should be an input
    or      dira,ClockPin 'p10
                            or      dira,DataPin 'p11
                            or      dira,OutputEnablePin 'p12
                            or      dira,ChargeSenseCapPin 'p13
                            mov     CirQueStartADDR, par
                            mov     CirQueWritePtr, par
                            mov     CirQueEnd, par
                            add     CirQueEnd, #128 'NOTE CHANGE TO ACTUAL
                            mov     CirQueStatusADDR,par
                            add     CirQueStatusADDR, ReadStatusOS
                            mov     ctra, CntrA_Cfg   'pos detection pin 15 for Counter A APIN
                            mov     frqa, #1
    Right as I start the discharge of the capacitor I do a mov phsa, #0
    Post Edited (Wurlitzer) : 3/29/2010 5:55:45 PM GMT
    edited 2010-03-29 19:10
    I have tried moving the counter A input to P14 just in case there was a problem with P15 but no luck.
    I have also changed from CntrA to CntrB with the same results.
    I appears the counter will never stop but can be reset.
    edited 2010-03-29 20:35
    I'm a little suspicious of statements like these, when the labels end with "Pin":
    Are the contents of those addresses actual pin numbers? Or their corresponding masks, i.e.:
    ClockPin          long    1 << 10
    edited 2010-03-29 20:38
    Yes Phil you are correct. I added the comments for posting purposes only. Thanks for checking.
    I set the original value exactly like you have shown.
    edited 2010-03-29 21:00
    In case anyone has the time to take a look, here is the RAW underdevelopment code. (I think I have it attached)
    edited 2010-03-30 02:49
    It's easy to overlook but that's not POS detection mode (NCO in fact). What you want is this (note the extra 0 in the right most bit group):
    binary  long    %0_01000_000_00000000_000000_000_001111
    again   long    %0_01000_000 << 23 | 0 << 9 | 15
    edited 2010-03-30 03:33
    Hoho, that will get you. Its better to do ((%01000 << 26) + 15)·than making the bit mask.
    Nyamekye,
    Post Edited (Kye) : 3/30/2010 2:46:35 PM GMT
    kuroneko! Thank you very much. I must have looked at that string of 1s and 0s for hours yesterday and never spotted that.
    The entire project works perfect now!
    Kye and Phil thanks again also for taking the time to look at this.
