PropBasic - ina[8..15] — Parallax Forums
camelot2camelot2 Posts: 54
edited 2010-03-30 02:14 in Propeller 1
hi, what I want to do is read the input register, P8 thru P15,
and assign it to a variable like in spin·· value := ina[noparse][[/noparse]8..15]
How can I do this in PropBasic ??· thanks
  • Gerry KeelyGerry Keely Posts: 75
    edited 2010-03-29 13:35
    I think all you need do is
    Pins PIN 8..15 INPUT
    value·var long
    Program Start
    Start:
    value·=Pins
    ·END
    Gerry
  • JonnyMacJonnyMac Posts: 9,843
    edited 2010-03-29 19:27
    Keep in mind that the order of your declaration affects the value you will get back from the pins -- be mindful of the LSB pin and MSB pin assignments. For example:
    Switch          PIN     7..0
    and...
    Switch          PIN     0..7
    ... have the LSB and MSB pins reversed, so having %00001111 on P7..P0 will return $0F with the first declaration, but $F0 with the second due to the reversal. As with Spin, this can be a useful feature.
    Jon McPhalen
    Hollywood, CA
  • camelot2camelot2 Posts: 54
    edited 2010-03-29 19:48
    thanks Gerry and JonneyMac for the replies. I tried it but it
    needs 16 ticks of the system clk. If I use value1 = ina then
    only 4 ticks are needed but then I have to apply a mask to get
    the desired bits. I want to use this 100 times to accumalate
    ADC data which would require variables value1 thru value100. Any
    thoughts as how to do this will be appreciated
    Use inline assembly if speed is a concern. Remember, compilers must be generalized and will not always give us the results we would hand-code.
    ASM
        mov     __temp1, ina
        shr     __temp1, #8
        and     __temp1, #$FF
      ENDASM
    At the end of this routine __temp1 holds the bits you seek; you can mix this into your PropBASIC code.
    Jon McPhalen
    Hollywood, CA
