Problem with IR detector and Easy Bluetooth module
i am using the the IR detector kit to do object detection and it the information is transferred to another robot via the easy bluetooth module.
so far i have been able to establish a transparent link between both modules.
i have done a code which transmits the signals detected by the Left IR sensor and transmits, but when the circuit is built for the right sensor, it does not work. i also retried a code from the basic stamps manual which was used to check the IR detection pairs and they work fine.
Can you all please assist in any way??
Thank you.
code for left IR and right IR
Thank you.
- Stephen
another problem i have encountered is that the left sensor is sending a value for both sensors and sometimes the right is sending.
