Basic Stamp 2 Reading Serial Data
Hi im Very New to this so any help apreciated.
I have a piece of test equipment that has a pic Controller inside. the Pic sends out serial data as soon as its connected and continues to send the same serial data untill its powered off.
I want to send the serial data from the Pic to the stamp and have the stamp display the data on the pc screen and later on a lcd display. Im not sure in what format the serial data is but i think its just 4 numbers.
and ideas welcombe
and ideas welcombe
- Stephen
Asynchronous serial communication
The piece of equipment has an output connector which is wired to one of the pic output pins. I have scanned the output with a scope and it looks like its TTL level.
I now have the Pic and the Stamp mounted on a vero board running from the same supply and the data out from the pic is connected to Data pin 8 on the stamp.
I can connect the scope to the data line and see data being transmitted but cannot read it.
I have spent two weeks on and off reading both the SERIN command and SEROUT commands and have still not managed to read any data from the pic.
Lynton
- Stephen
What is the data baudrate, parity, data bits, stop bits from the test equipment?
Does the test equipment manual describe what the data string looks like?
With these answers, getting the Stamp to listen should be quite doable.
Tom Sisk
http://www.siskconsult.com
Hi Mike Thanks for your Help.
The pic is 12F629 Both the program and the data is protected i have tried to read it but no joy. I have No circuit diagram although it looks a very simple circuit with only about a dozen components. I haven't tried programming pic chips yet, This was my first attempt and by the success I'm having so far I may not try many more.
HI the test equipment was manufactured in china by a company whom have now ceased to exist. The instructions are very poor and say nothing about the communications used. The individual pieces of test equipment have their own unique identifier stored in the pic no other data is sent or received. When the units are plugged into the base unit for charging the base unit recognises which piece of test equipment is on charge and records the charging details for record. If i change the Pic from one unit to the other the Base unit then assumes the id is of the second unit.
Lynton
This will require some benchtop investigating, doing some sample sniffing as was noted previously. If the data is only an ID, the exercise may not be worth the trouble, other than the intellectual stimulation of solving the riddle.
Cheers,
Tom Sisk
