Tsl230r help!!!
TSL230R Just can output the frequency·by the light change how can i set the frequency to the lux
My program is a basic stamp program and i just copy from the data sheet but i don't know how to change the frequency to the lux
- Stephen
One way to calibrate approximately is to put your sensor 1 meter from a 100 watt standard bare light bulb, or 1 meter from the center of the beam of a 50 watt R20 track-light bulb. That gives in the neighborhood of 400-500 lux. Outdoor full sunlight is in the neighborhood of 100000 lux.
Remember that lux is a photometric quantity that measures how well human eyes can see things, and defines a peak in yellow-green light at 555 nanometers. The sensors you have measure over a much wider range of wavelengths than eyes can see. That TSL230 would give a reading even under an invisible IR LED. Sensors for lux usually have a filter that cuts out the non-visible wavelengths and peaks follows the so-called photoptic curve of the eye's sensitivity.
Tracy Allen
www.emesystems.com
