Using Serial cables with propeller?
hey guys, im just starting to use the propeller but i was wondering, instead of using a prop plug coulf you make your own serial cable adaptor instead? would spin even see it on the COM port if you used a serial cable?
"When the government is afraid of the people there is liberty, when the people are afraid of the government, there is tryanny"
· Thomas Jefferson
· Thomas Jefferson
www.smarthome.viviti.com/propeller
The Wulfden P1 adapter ($5 + shipping) is available here www.wulfden.org/TheShoppe/pa/index.shtml
Dr_Accula has modded his ver 6 of the DracBlade board to select the negative going edge via a PNP transistor, but I have yet to try this. I often get a failed connection on the first try, but after that it works every time.
Style and grace : Nil point
You may wish to check out my SerPlug
mikronauts.com/products/serplug/
www.mikronauts.com E-mail: mikronauts _at_ gmail _dot_ com 5.0" VGA LCD in stock!
Morpheus dual Prop SBC w/ 512KB kit $119.95, Mem+2MB memory/IO kit $89.95, both kits $189.95 SerPlug $9.95
Propteus and Proteus for Propeller prototyping 6.250MHz custom Crystals run Propellers at 100MHz
Las - Large model assembler Largos - upcoming nano operating system
