LOOKING FOR INFO Has any one ever used a TLC5490NT with a Basic Stamp — Parallax Forums
sam_sam_samsam_sam_sam Posts: 2,286
edited 2010-03-28 10:12 in General Discussion
Can you share your code with me
Here is the data sheet for it
http://focus.ti.com/lit/ds/symlink/tlc5940.pdf
··Thanks for any·idea.gif·that you may have and all of your time finding them smile.gif
Sam
Post Edited (sam_sam_sam) : 3/28/2010 1:47:08 AM GMT
    edited 2010-03-28 00:06
    I've had a TLC5940 object in the Propeller Object Exchange for some time. The code could be made to be much faster and more efficient, but it has worked reliably for years. obex.parallax.com/objects/375/
    Timothy D. Swieter, E.I.
    www.brilldea.com - Prop Blade, LED Painter, RGB LEDs, 3.0" 16:9 LCD Composite video display, eProto for SunSPOT, PropNET, PolkaDOT-51
    www.tdswieter.com
    edited 2010-03-28 01:47
    Timothy
    Thank You for your reply
    Can you tell me what Pins on the Propeller are which pin on the TLC5490
    Sam
    edited 2010-03-28 06:01
    The pin wiring depends on your application. The TLC5940 object allows you to use any pin. When starting the object you specify which signals are which pins. Look at the TLC5940 data sheet and I think you will see similar names as used in the object start method.
    PUB StartTLC5940(_sclk, _sin, _xlat, _gsclk, _blank, _vprg, _dcprog)
    www.tdswieter.com
    I just now noticed the title of your thread included "Basic Stamp". Obviously the code I linked to was for the Propeller, but I think you got that. The basics is to clock data out and then latch it in. A second task is a continuously clocking signal that counts to 1023 as the gray scale clock.
    www.tdswieter.com
