Question about Repeat and Quit — Parallax Forums
karakikokarakiko Posts: 11
edited 2010-03-27 22:46 in Propeller 1
Hello forum,
I am using the Parallax Serial Terminal to send ASCII strings to run a routine, the routine is :
PUB LedOnOff( num,value )
 repeat
  test2.writeLed1(0,0)
  test2.writeLed1(1,250)
  test1.writeLed(1,250)
  test1.writeLed(0,250)
  WaitCnt(OneSecond + Cnt)
when i am writting in PST LednOnOff the routine is running and the program is working good, but sometimes i need·to quit from this loop, how·can i do this ?
Thanks in advance,
Karakik
  • pullmollpullmoll Posts: 817
    edited 2010-03-27 15:09
    karakiko said...
    how can i do this ?
    With the quit instruction. It leaves the level of repeat you are in and continues as if the repeat condition had expired. A repeat alone has the condition "always", but quit still leaves the loop.
    He died at the console of hunger and thirst.
    Next day he was buried. Face down, nine edge first.
  • karakikokarakiko Posts: 11
    edited 2010-03-27 15:38
    Thanks , but how i can call quit to stop the repeat ?
    edited 2010-03-27 15:47
    Read the Propeller Manual section on the REPEAT statement and the QUIT statement. There are plenty of examples there.
    edited 2010-03-27 19:54
    karakiko said...
    You will have some condition when to quit? If the name of that condition is test_quit, then you just do
     repeat
      if test_quit
        quit
  • JonnyMacJonnyMac Posts: 9,801
    You may need to do multiple tests if you're using nested repeat loops as I was in a recent project. I have a "background" process running that uses stacked repeat loops; the foreground can tell the process to terminate by setting a global flag; I had to include tests in both loops to get the correct behavior. It's not difficult, it's just a detail.
    Jon McPhalen
    Hollywood, CA
