Wish me luck — Parallax Forums
Wish me luck
sylvie369sylvie369 Posts: 1,622
edited 2010-03-30 07:17 in Propeller 1
Weather permitting, I'm going to fly my XBee-MAWD pull-pin telemetry device later today, in a high power rocket, using a Prop Protoboard with a 4x20 LCD as the receiver. I just finished the altimeter bay this morning (keeping up the rocketeers' tradition of doing things at the last moment before a launch), and everything works fine in ground testing. The hardest part was probably putting together a connector from the altimeter to my custom pc board, as the altimeter end uses one of those tiny Molex Picoblade connectors.
This is my first real project using·a Prop programmed to do things in parallel, as I have one cog receiving altitude data, one cog receiving pull-pin status, and one cog continually updating the LCD based on the state of a buffer that the first two cogs write to. I got a lot of good help with this on the forum - thanks. It's also my first real project using a pc board of my own design, one that I made up in Eagle and had produced at BatchPCB.
If I don't destroy the rocket on that flight, I'll put up my GPS tracker transmitter on a second flight of the same rocket. There's no Prop on that project yet - I'm just sending the rocket's position to a terminal program on my laptop on the ground. I've been working on a program for the Prop to parse the received GPS data for display, but I wasn't able to finish that program in time for this launch. Hopefully over the summer, again assuming I don't destroy it all today.
  • RsadeikaRsadeika Posts: 3,858
    edited 2010-03-27 14:13
    Good Luck, on your rocket flight. I think, we would get more excited, if you had some pictures of your setup, and the flight. I visit other forums, and seems like more people are starting to get interested in hobby rocketry. Waiting for some pictures ...
    Ray
    edited 2010-03-27 14:19
    Sounds like an interesting project.· I'm into rockets also, as you can probably tell from my avatarsmile.gif .· It sounds like the prop is used for the ground terminal.· Do you have any plans to fly a prop in the rocket in the future? ·I'm hoping to develop an IMU using the prop, and eventually use it to control a gimballed motor mount in a finless rocket.· I built a gyro-controlled rocket using an SX, but the prop can do so much more.
    Dave
  • WhitWhit Posts: 4,191
    edited 2010-03-27 15:19
    Break a leg...
    Whit+
    edited 2010-03-27 17:12
    This is a really great project and it sounds like you've made great accomplishments with prop software utilizing multiple cogs. Congratulations on your success! Make sure those molex connectors are rock solid in their fastening. It's good that your weather has perked up enough to launch and we'll hope for no wind. I know the excitement and anticipation of putting up these payloads from my own space program.
    humanoido
    *Stamp SEED Supercomputer *Basic Stamp Supercomputer *TriCore Stamp Supercomputer
    *Minuscule Stamp Supercomputer *Tiny Stamp Supercomputer *Penguin with 12 Brains
    *BASIC Stamp Supercomputing Book *Three Dimensional Computer *StampOne News!
    *Penguin Tech *Penguin Robot Society *Toddler Humanoid Robot Project
    *Ultimate List Prop Languages *Prop-a-Lot *Propalot Stuff *Prop SC Computer
    *Prop IB Hypercomputer - under development *Hobby Space Program
    edited 2010-03-28 00:09
    Good luck!! (And post some pictures please of the setup. It is always inspirational to see other peoples work.)
    Timothy D. Swieter, E.I.
    www.brilldea.com - Prop Blade, LED Painter, RGB LEDs, 3.0" 16:9 LCD Composite video display, eProto for SunSPOT, PropNET, PolkaDOT-51
    www.tdswieter.com
  • sylvie369sylvie369 Posts: 1,622
    edited 2010-03-28 00:39
    Unfortunately, I can't take photos while I'm setting up and flying this stuff. Here are a few photos of the device that goes in the rocket, and one of the receiver device. I'd love to have more photos, but I just can't manage to take 'em while I'm doing all the setup.
    I flew the fancy telemetry thing on an I285, and the electronics worked perfectly. Unfortunately, the main parachute got jammed up and didn't come out, so I crashed, destroying the upper tube and the electronics bay. The electronics themselves are fine - I'll just have to get a few more tubes, redrill the holes, reinstall the wiring, and so on.
    I started getting altitude data right on schedule, and called out altitudes into the PA system. It reported a peak altitude of 2001 feet (which is just perfect in my book...), and then right on cue, the flight status indicator on the telemetry readout went to "Descending", and then the indicator for the apogee event went on, right as the drogue charge on the
    rocket blew. I called out altitudes on the way down, and right at 500 feet, the indicator for the main parachute event went on, the main blew, and about 20 seconds later, I landed, at which point the "flight status" indicator changed to "Landed". Since I didn't watch the rocket itself at all, I didn't know I'd crashed until I got out to where it had landed.
    So I have somewhat mixed feelings. That was a lot of work to have to do over again before the next launch, but I can build a slightly better version now that I'm practiced and have some time, and none of the expensive stuff was damaged. And everything worked properly! This was easily the most sophisticated piece of electronics I've seen in any of our rockets, and it
    all worked as planned.
    I used a Celestron "Power Tank" as the power supply for the receiver,·with a cigarette lighter - 7.5V converter·going from one of the lighter ports on the Power·Tank to the power connection on the Prop Protoboard.·That worked just fine, and was pretty convenient.
    I'll rebuild the electronics bay soon, and hopefully have a good version of everything to show off at·the Prop Expo near Chicago in a month and·a half.
    Paul
    Post Edited (sylvie369) : 3/28/2010 12:48:52 AM GMT
    3264 x 2448 - 1M
    3264 x 2448 - 2M
    2448 x 3264 - 2M
    edited 2010-03-28 00:48
    I really like the rocket mounted equipment!! So the system is as "simple" as gather the data on-board and radio is back? I can imagine how you were watching the details of the altitude and missed the whole crashing event!
    www.tdswieter.com
  • hinvhinv Posts: 1,255
    edited 2010-03-28 01:35
    Wow, that some rocket! What do you use for a motor with all of that threaded rod to lift?
    edited 2010-03-28 02:49
    hinv said...
    http://www.apogeerockets.com/Cesaroni_38mm_Casings.asp
    Today I used a Pro 38 4 grain I 285 motor. It's about a foot long, 38mm in diameter, made up of Ammonium Perchlorate Composite Propellant. Later I flew the rocket on a 5-grain J375 - essentially·25% more motor. We fly much larger things than this. This rocket weighs about 8 pounds empty (that is, before the motor is installed). I've seen rockets weighing 10-20 times that much fly at our field. Our largest motors are 4" in diameter and about 4 feet long. The largest I've flown was a K motor about 2" in diameter and 14" long, easily lifting a 16 pound rocket to 3800 feet.
    This setup does just send the data directly from the altimeter and pull-pins to the XBee, without an intervening computer. There's no reason why there couldn't be an onboard Propeller, though, and I assume I'll do that sometime in the next year or two. But it's always better to keep as much hardware on the ground as possible. If I can do it without an onboard computer, I will.
    Post Edited (sylvie369) : 3/28/2010 2:56:46 AM GMT
    edited 2010-03-28 05:59
    If you had an on-board computer you would could various experiments or data logging in addition to sending telemetry related data back to a ground station. For instance you could have temperature and light sensors as well as your GPS and altitude sensors. The data could be logged to an SD card and packets of the data could be sent back to mission control.
    www.tdswieter.com
  • wyzard28wyzard28 Posts: 24
    edited 2010-03-28 07:45
    You could also use a Propeller to monitor the main chute deployment and trigger an alternate chute's deployment if the main fails. It could also watch the altimeter and deploy an additional backup chute if the rate of descent is too fast.
    You also could add a 20-30 G 3-axis accelerometer to the mix. If watching Sparkfun's trebuchetted pumpkin's acceleration data was instructive, imagine what forces are generated by one of your 5 grain liftoffs will look like!
    edited 2010-03-28 09:01
    Timothy D. Swieter said...
    I've flown a datalogger for acceleration (+/-25G) and external temperature (using the really nice fast response sensor that Vernier sells). That was back in the days when I didn't know how to design my own stuff, though. I do intend to eventually do a better version of that. I'd prefer to stay away from onboard SD cards, though: I've found that they don't necessarily stay in their sockets when the ejection charges fire.
    Wyzard28 said...
    I'm working on getting computers to fire ejection charges. I've got a MOSFET circuit breadboarded here, design taken from a commercial altimeter, which works fine. I don't understand the continuity check part yet, though, and that's important. We generally don't fly unless something beeps on the pad to tell us that our charges are going to fire.
    It's not that difficult to get a rocket to exceed 20Gs on liftoff - I supervised·a Level 1 certification flight yesterday by a guy who used a "VMax" H400 motor that probably put him over 20Gs. I've managed to surface mount a Freescale MMA6255AEG 50G two-axis accelerometer onto a DIP adapter board without screwing it up, and I'd go with something like that, maybe paired with a 20G one (though as soon as you have two measures of the same variable, you wind up not knowing that variable's value - in common English, the man with two watches never knows what time it is).
  • mikedivmikediv Posts: 825
    edited 2010-03-28 13:37
    sylvie369,, good luck sir, But I have to ask the rig looks kind of heavy how big is the rocket??? I myself have never seen anything bigger than an Este D rocket engine but I do not think that would lift your payload?
    edited 2010-03-28 14:04
    mikediv said...
    A D motor won't come anywhere near lifting this stuff. In motor size, each letter has twice the total impulse of the previous letter, so an E is equal to two D motors, and so on. I flew the telemetry stuff yesterday on an I motor, one with 510 N-sec of total impulse, as opposed to·16.8 N-sec with an Estes D motor. In short, I had about 27 times as much total impulse.
    Attached are a couple of photos of rockets of the kind of size I'm talking about. The colorful one is 4" in diameter, something a little over 6 feet tall, about 6 pounds, and about the size of what I used for these telemetry flights. The other photo is one of my largest rockets, 5.5" in diameter, 8 feet tall, about 15 pounds, and flew on a K550 motor (about 90 Estes D motors) to about 3000 feet carrying a wireless remote control for parachute deployment. My group won a $500 "Best non-engineering group" prize for that project from the NASA Space Grant Consortium.
    2272 x 1704 - 1M
    1600 x 1197 - 178K
  • AleAle Posts: 2,363
    edited 2010-03-28 16:19
    Hei Paul,
    looking at your rocket project and at the balloon-enabled cameras launched some months ago I was wondering if a rocket could be lifted by some balloons and the ignited when at some km of the surface, using large balloons... Is it possible ? feasible ?
    ps: I think this is really cool.
    thanks !
    Visit some of my articles at Propeller Wiki:
    MATH on the propeller propeller.wikispaces.com/MATH
    pPropQL: propeller.wikispaces.com/pPropQL
    pPropQL020: propeller.wikispaces.com/pPropQL020
    OMU for the pPropQL/020 propeller.wikispaces.com/OMU
    pPropellerSim - A propeller simulator for ASM development sourceforge.net/projects/ppropellersim
  • ScopeScope Posts: 417
    edited 2010-03-28 16:26
    Wow
    Good luck
    Very cool
    edited 2010-03-28 17:32
    Ale, I wondered the same thing.
    Graham
    edited 2010-03-28 21:51
    There's a group somewhere flying "rockoons" - lifting high power rockets under large balloons and launching them from altitude. I don't remember their name offhand, but I think their motto is "America's Other Space Program". If you're interested, you could either Google that or just "rockoon", and you'll find something, I'm sure.
    It was too windy for me to fly rockets today, but I did ground test my XBee GPS transmitter. It seems to work fairly well. I turned on the transmitter, connected an XBee through the Parallax USB board to my netbook, opened a terminal window and turned on data capture to file. I also carried my handheld Garmin unit, and took a little walk around the park, down into a ravine, and through some woods, to see how well the XBee Pro on my transmitter stayed in contact with the one on the netbook sitting on the trunk of my car back at the range head.
    One problem I'm going to have to get to is that my netbook goes to sleep after a while, and so stopped receiving before I'd gotten back to the car to turn it off. The file was fine, though. You can see in the third image below the track from my transmitter in magenta (red, whatever...) superimposed on the track from my Garmin handheld in blue (cyan?). It tracks pretty well, except a bit in the lower left corner, where I walked down into a ravine and was no longer even close to line-of-sight to my car, which was .27 miles away. I'm pretty confident that if I were to carry the receiver with me I'd be able to stay in better contact. More importantly, after I lose contact, I was easily picking it up again when I did get up on a little hill in the extreme lower left corner. It's almost inevitable that you're going to lose contact: regaining contact gracefully is what really matters.
    I should have gone further back into the woods, but there were dog trainers with live ammunition back there, and I wasn't wild about getting too far away from the runway.
    Post Edited (sylvie369) : 3/28/2010 10:31:13 PM GMT
    3264 x 2448 - 729K
    1110 x 678 - 78K
    926 x 737 - 89K
    edited 2010-03-29 03:37
    Those rockets look fun. I'm looking forward to an update and more photos.
    I wonder, has anyone attached a camera to the rocket? cgi.ebay.com/2GB-Spy-Car-Key-Chain-Camera-DVR-Webcam-Video-Recorder_W0QQitemZ290419297473QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item439e56ccc1
    I stuck one on a model helicopter and flew around my house www.youtube.com/watch?v=igs_P5cyvls They are very light and while the vibration would make for a shaky video going up, I reckon you would get some nice footage on the way down.
    www.smarthome.viviti.com/propeller
    edited 2010-03-29 13:59
    The rockoon guys are JP Aerospace ( http://www.jpaerospace.com/ ).· They have launched a few rockoons, but they mostly do balloon stuff.
    There are several rocket videos on YouTube.· There used to be a YouTube group called the rocketry stage, but YouTube has changed during the past year, and I don't know if that group exists any more.
    There are many aerial photos, and a few videos posted at the Flickr group at http://www.flickr.com/groups/rap/ .
    Dave
    edited 2010-03-29 16:39
    Thanks, Dave. Oh, by the way, I'm very familiar with your gyro stabilized rocket - I've watched the video quite a few times. Very impressive.
    Dr_Acula said...
    As Dave said, lots of rocketeers have onboard video. We took a nice video the weekend before last using a small USB camera from Boostervision. Generally you get far better video on the way up, as long as you keep the spinning to a minimum (by attaching your fins squarely), because coming down under parachute causes a lot of vibration. In addition, it's hard to get the camera to point at anything other than sky and parachute as it shakes around like that. On the way up, though, it's easy to just have it pointed down along the body tube. That's what almost everyone does, though I've seen some pointed out more sideways.
    Those guys of JP aerospace have quite interesting things... I only have to find such a group here in DE (or start my own). Too much Star Trek I think wink.gif
