PWM Pal
Tumbler
Hello
I'm searchin for a PWM Pal -like chip or module.
The parallax pwmpal has only 4 pwm outputs, i need at least 15
Anyone knows such one?
@parallax: is it possible to order a modified pwmpal with 15 pwm outputs? I don't need the inputs. Only the serial link bs2<>pwmpal (PINO)
You'd connect all the PWMpal Vdd, Vss, and Reset pins together to the same pins on the Stamp. Each PWMpal's P0 would be connected to a separate Stamp I/O pin and the 4 output and 4 input pins of each PWMpal would be available for connection to your devices.
Post Edited (Mike Green) : 3/27/2010 5:31:23 AM GMT
Looking at the sx20 sheet, i see it has 12 input/outputs, but couldn't find if they all can programmed as pwm outputs.
But thx for answer this
