Alcohol and a tooth brush
I read·a recommendation here somewhere to use isopropyl alcohol and a toothbrush to clean a PCB dirty with flux residue.· Is that still advisable on a PCB with parts (SD card adapter, headphone jack, etc.)·which could trap the moisture of the alcohol?· How long to let dry before powering up?· Does alcohol even conduct electriciy?
Thanks.
Thanks.
24 bit LCD Breakout Board now in. $24.99 has backlight driver and touch sensitive decoder.
If you have not already. Add yourself to the prophead map
John R.
Click here to see my Nomad Build Log
John R.
