Linear Voltage Regulators vs. Switching Regulators
ElectricAye
I'm designing a stepper motor controller PCB that uses 24 volts to drive the motors, but the other on-board circuits (Propeller, other ICs, etc.) only use 3.3 volts and 5 volts. I suppose I can tap into the 24 volt power supply and then use a number of linear voltage regulators to step down the voltage to a final 3.3 volts, but I'm guessing there are right ways and wrong ways to make those steps. For example, is it wise to simply jump from 24 volts to, say, 9 volts all in one leap? Or is it better to step down to, say, 18 volts, then 12 volts, then 5 volts, then 3.3 volts? I'm guessing the bigger the leap, the more power that gets wasted, but I don't really know for sure.
Anybody know a good rule of thumb for deciding how to step down voltages?
many thanks,
Mark
Post Edited (ElectricAye) : 3/26/2010 2:12:01 AM GMT
many thanks,
Mark
You might consider adding a 6-volt battery just to power your electronics. There will be much less power to dissipate, and many times, it's advantageous to isolate your motor batteries from your electronics batteries to avoid interference.
John R.
Click here to see my Nomad Build Log
Many times, a linear is fine as long as you pay attention to the V x I drop and provide adequate heat-sinking. At high current and high input voltage, you are fighting a losing battle, especially on battery operated equipment.
Cheers,
Tom Sisk
http://www.siskconsult.com
Just don't use any until there are plenty around. I need them for my projects.
I've never played with switching regs before. They sound intriguing. I have no idea how to spec them out so I was looking at the following:
www.national.com/ds/LM/LM1575.pdf
Thanks, you guys. This was something totally new to me.
www.dimensionengineering.com/DE-SWADJ3.htm
or this one can go from 30v down right to 3.3v.
www.dimensionengineering.com/DE-SW033.htm
-dan
Arguing with myself--sometimes me, myself, and I don't always agree.
(Former) Caterpillar product support technician
Erco stated things very well.
Z = (Vin - Vout) * current
Where Z is defined as all of the following: Dissipated power, wasted power, heat generated, size of heatsink needed, finger burnability, etc
Dropping 24 volts to 5 volts at only 300mA will still require a regulator/heatsink that can dissipate 5.7 watts. You could do that in steps to limit the amount of heat each regulator is dissipating, but the total wasted energy (dissipated heat) is the same.
Andrew Williams
WBA Consulting
WBA-TH1M Sensirion SHT11 Module
Special Olympics Polar Bear Plunge, Mar 20, 2010
There are lots of these, but they're not smoke-proof.
Dan, WBA, PJ,
thanks you guys for all the suggestions and the info on how the Linear Volt Regs enhance finger burnability. For my recent prototype I had to go with the linear regs but in my next version I'm definitely going to incorporate some of these highfalutin converters y'all have been telling me about. I only wish I'd asked the question earlier.
bless you all,
Mark
24 bit LCD Breakout Board now in. $24.99 has backlight driver and touch sensitive decoder.
If you have not already. Add yourself to the prophead map
