project
hi guys,
Im new to this kind of stuff and i was hoping you guys could help
My project entails creating a device that cools IV fluid to 4 degrees C. I want to measure the temperature of this fluid and keep the fluid at 4C. So thus i was thinking of using a IR temp sensor with a feed back loop and alarm. The feed back loop would turn my power supply on and off depending on the temperature for regulation.
For example, my fluid rose from 4 C to 6 C, thus my device would turn on
fluid dropped from 4 to 2C my device would turn off
fluid rose to 10 C ( alarm would sound and would turn on)
However i don't exactly know what parts to get.
I was thinking of getting this:
MLX90614 Infrared Thermometer Module (90° FOV). I assume the BASIC Stamp 2 is the microprocessor?
How do i load My program to this micro processor?
What other parts do i need to buy?
What would be a good alarm, and LED display(to show temp of fluid at all times)?
Ps. please don't assume i know anything... because i don't..
Thanks for all help in advance.
Leon Heller
Amateur radio callsign: G1HSM
JLD7100 Temperature Controller
Specification
Power:AC(85V~265V) or DC(85V~360V)
Power consumption: 2Watt<
Range:-1999~9999
Sampling: 4/s
Relay output AC220V, 3A
Multiple sensor: T,R,J,B,S,K,E,Wre3 ~ Wre25 , PT100, Cu50
Accuracy: 0.2%
Dimension: DIN: 1/16 (48mmX24mmX75mm)
Hole: 45mmx22mm
The BS2 is the microcontroller, Yes. It's programmed through the RS323 port (serial port) on your computer OR a USB to serial adapter available from Parallax. A variant of BASIC is the language.
Just a couple thoughts:
Since IV fluid needs to be sterile, I'd think you need a non-contact sensor, or outside the fluid....
Buzzers for the alarm is available through Parallax, or Radio Shack.
7 segment LED displays would be the easiest to use (I think) and probably the cheapest. LCD would be MUCH nicer and more expensive / and potentially more difficult to interface for the beginner.
I don't have any ideas on selecting the temp probe. It will probably be 0-5V, 0-10V, 0-40mA or some variety of voltage or current. In any case you'll need a ADC for arguably the best precision, or use the RCTIME command might work just as well without the ADC (Analog to digital converter)
Cool project. What will you use for the heater / cooler??? Peltier?
"puff"...... Smile, there went another one.
Hope this helps!
Spiral -- im definetly using a IR sensor. And i meant LED not LCD [noparse]:)[/noparse] . And yes im using a peltier!
kf4ixm- the 10 degree might be worth it for the extra 10 dollars. I might have to use the RS323 port instead of the educational board, i dont think i can drop 100 on a usb adapter( my teachers might not agree to pay for that)
Personally, I think the LCD is easier to use. All you need is a SEROUT statement, while a 7 segment display requires figuring out how to display a string of letters and multiplex them or otherwise control it.
@James - you could also use the homework board, although my searching right now has shown that apparently Parallax doesn't sell them in individual sets (just a 10 pack). Anyway, you could also go with a BS2 module and get a carrier board, assuming that you know or are willing to learn how to solder.
For your display I'd just use four LEDs: one for normal, one for low temperature, one for high temperature, and one for dangerous out of range temperature.
The temperature sensor does not have a BS2 onboard that you can program. You will need an external microcontroller. There are also other (read cheaper) microcontrollers out there, but they are more difficult to use and take more background knowledge. The Propeller from Parallax is one.
Finally, a PID controller would be a software feature, not a hardware feature. It wouldn't cost you money, unless you charge for your programming time.
Powered by enthusiasm
A lot of computers (laptops) are being shipped RS232 delete, so the USB adapter is required. If you can run RS323, do it.
