Propeller Fortune Teller — Parallax Forums
william chanwilliam chan Posts: 1,326
edited 2010-03-26 02:59 in Propeller 1
I bet you guys thought that everything that can be invented with Propeller I has already been invented.
Presenting...
A Propeller based palmistry fortune teller.
Place your hand in front of the USB camera and your fortune for tomorrow will be displayed!
Anybody need a sample for your own crazy experimentation, please PM me.
After all, we already spent a fortune on the large enclosure mould.
www.fd.com.my
www.mercedes.com.my
Post Edited (william chan) : 3/25/2010 7:03:40 AM GMT
400 x 600 - 45K
400 x 600 - 47K
800 x 533 - 35K
800 x 533 - 45K
  • pullmollpullmoll Posts: 817
    edited 2010-03-25 07:44
    william chan said...
    Bw........ *pfff*
    It looks like you have a miniATX PC board in there? Is that for the (USB?) camera?
    He died at the console of hunger and thirst.
    Next day he was buried. Face down, nine edge first.
    Post Edited (pullmoll) : 3/25/2010 9:05:10 AM GMT
  • TonyWaiteTonyWaite Posts: 219
    edited 2010-03-25 08:40
    What a great project!
    Tell us about its capabilities and that gorgeous enclosure ...
    T o n y
  • william chanwilliam chan Posts: 1,326
    edited 2010-03-25 09:16
    pullmoll said...
    Yes, the propeller can't directly read from the USB camera.
    It is a mini-ITX board running Windows XP from a USB Thumb drive!
    This board is fanless, low profile, runs at 1.6GHz and has a built-in power supply onboard!
    There is also a usb Wifi module stuck to the inside wall.
    The enclosure has a finger guide and a wrist rest.
    It took us one year to design the fanless enclosure.
    The entire product consumes only 12 watts when idle.
    www.fd.com.my
    www.mercedes.com.my
    Post Edited (william chan) : 3/25/2010 9:33:12 AM GMT
    edited 2010-03-25 11:19
    Truely a masterpiece of design! Did you use statistics to elicit the average distance between the wrist and the fingertips, or did you take your own hand in hand?
    Thanks for the info!
  • LeonLeon Posts: 7,620
    edited 2010-03-25 11:45
    Many years ago, I and a friend of mine at English-Electric-Marconi Computers designed and built a machine that detected whether someone was male or female, for a party. We filched all the parts from work. People had to stand with their legs apart and their feet on two metal plates, a button was pressed, lots of lights flashed, uniselectors rotated, and relays clicked, and then one of two bulbs labeled Male or Female lit up. It was very accurate, out of about 50 people it got two wrong. Can anyone guess how it worked?
    Leon Heller
    Amateur radio callsign: G1HSM
    edited 2010-03-25 11:50
    Trousers or dresses ?
    Not so accurate for Scots.
    Style and grace : Nil point
    edited 2010-03-25 12:08
    I think you've got it! In those days, men usually wore dark trousers and girls wore short skirts with sheer stockings (tights hadn't been invented). The two it got wrong were the girl I was with who wore a long black dress, and a chap wearing light coloured trousers. It would probably have got a kilted Scot right if he'd been wearing dark socks.
    A Propeller would be ideal for an up-to-date version. All it would need is an ADC for the light sensor, sound generation and video output.
    Leon Heller
    edited 2010-03-25 12:12
    Somebody pressed another hidden button to get the result.
    www.fd.com.my
    www.mercedes.com.my
    edited 2010-03-25 12:38
    Leon said...
    ...then one of two bulbs labeled Male or Female lit up. It was very accurate, out of about 50 people it got two wrong. Can anyone guess how it worked?
    Leon, that's too easy. All the people at the parties you went to were dudes.
    edited 2010-03-25 13:27
    Leon Heller
    edited 2010-03-25 16:03
    Nice looking unit! I'm sure you did spend $$$ getting that molded. I'm preaching to the choir, but:
    Plastic injection molds are very expensive, not at all cost effective for small runs.
    Vacuum forming is a much cheaper alternative for low volume items, but does require lots of hand fabrication to cut windows, drill holes, and add screw bosses.
    edited 2010-03-25 20:52
    pullmoll said...
    We just copied the distance from some mechanical datasheet created by a multinational company.
    But we had to extend it longer by 1 cm due to space considerations.
    Erco,
    Nobody does vacuum forming in our country.
    Can vacuum forming make screw stands to mount the PCB and the back cover?
    I can't imagine vacuum forming such a complicated enclosure.
    I think the best solution is to make injection moulds in a low cost country like ours.
    www.fd.com.my
    www.mercedes.com.my
    Post Edited (william chan) : 3/25/2010 9:02:05 PM GMT
    edited 2010-03-25 23:59
    Very cool project. Interesting mix of a PC and the propeller for a finished project.
    The enclosure looks a lot like that of a Wyse Winterm 9650XE that had a VIA Mini-ATX and 15" LCD packaged together.
    images.google.com/images?q=wyse%209650XE
    I have one hacked that is running XP Pro from a 40gb HDD instead of the XP-Embedded that was on the 512MB 40pin IDE flash disk.
    (I was going to use it to make my toolbox PC before I got a hold of some FIC IONs)
    Andrew Williams
    WBA Consulting
    WBA-TH1M Sensirion SHT11 Module
    Special Olympics Polar Bear Plunge, Mar 20, 2010
  • mparkmpark Posts: 1,336
    edited 2010-03-26 01:25
    What exactly is the Propeller's function in this? Just interfacing keypad and LCD?
    How do you know if the fortune teller works? I mean, how accurate are the predictions? [noparse]:)[/noparse]
    edited 2010-03-26 02:15
    mpark said...
    I'm guessing it runs an algorithm that incorporates some esoteric ancient Chinese secret. Orrr....
    No matter who uses it, it displays "You're gullible as all get out." and it's right 100 percent of the time. lol.gif
    edited 2010-03-26 02:28
    mpark said...
    Besides interfacing the keypad and lcd, it also serves as a watchdog to watch the PC and it's programs
    and makes sure the programs are running fine with heartbeat.
    If no heartbeat from the PC programs thru the comm port, the propeller will hard restart the PC using it's solid state relay connected to the PC's on-off header.
    www.fd.com.my
    www.mercedes.com.my
  • sylvie369sylvie369 Posts: 1,622
    mpark said...
    It's a fortune teller - it doesn't have to be accurate.
    This from my morning paper:
    Morning paper said...
    The "Up Close & Personal" show featuring Montel Williams and psychic Sylvia Browne scheduled for Monday at the Milwaukee Theatre has been canceled. The promoter blamed "unforeseen circumstances."
