Decting Vibration
GaryB
We have a rocket project·where we want to use a Basic Stamp to detect and record vibration during the flight. I've seen the Piezo strip, but looking though the forums, we haven't been able to figure out how to program it to record vibrations.
Questions:
1. Is the Piezo strip the best way to detect vibrations?
2. If not, what would do the job?
3. Regardless of sensor, we need assistance in writing/modifying the code, is there help somewhere?
Thanks in advance - Gary
Questions:
- Stephen
Gary
- Stephen
We are using two as identical as possible high powered rockets with the same stamp/sensor shifted from one rocket to the other to establish some baseline data. Then we will modify one of the rockets to see if we can reduce the vibration. So with that in mind, which sensor makes the most sense (pun intended)? And, once that is determined, how do we program it?
Thanks - Gary
- Stephen
Gary
