propmodule current draw
I was asked today why the propmodule draws so much current. Here is my experimental tests:
S - Switching Regulator
D - No switching regulator
H - test hc.spin
L - test lc.spin
5 - Vin 5V
3 - Vin 3.3V
Over voltage protection connected
SH5: 79.0mA
SH3: 130.0mA
SL5: 19.2mA
SL3: 25.8mA
DH3: 86.2mA
DL3: 17.8mA
Over voltage protection removed:
SH5: 63.7mA
SH3: 101.8mA
SL5: 4.4mA
SL3: 2.9mA
DH3: 77.4mA
DL3: 35.2uA*
As to be expected module draws more current using the switching regulator at lower voltages and less current at higher voltages. I was surprised how much current the over voltage protection draws. if you need really low power and you are careful not to apply voltages higher then 3.9V cut the large black diode on the back of your module off.
*current is average current draw over time. actual current fluctuates between 7.8uA and 86.6uA
24 bit LCD Breakout Board now in. $24.99 has backlight driver and touch sensitive decoder.
If you have not already. Add yourself to the prophead map
H - test hc.spin
L - test lc.spin
5 - Vin 5V
3 - Vin 3.3V
SH5: 79.0mA
SH3: 130.0mA
SL5: 19.2mA
SL3: 25.8mA
DH3: 86.2mA
DL3: 17.8mA
SH5: 63.7mA
SH3: 101.8mA
SL5: 4.4mA
SL3: 2.9mA
DH3: 77.4mA
DL3: 35.2uA*
- heliboy
- heliboy
it would be a good idea to lose the zener.
humanoido
Doesn't the module use a buck-boost converter?
I would like to use 2 AAA's for projects, but if that's the power profile, I'll have to give up that idea.
For now I use a 3AA NiCad on most battery-powered projects without a regulator and even a fully charged pack never exceeds 4.2VDC.
Short answers?
Not available since you deserve more information than you requested.
May the road rise to meet you; may the sun shine on your back.
May you create something useful, even if it's just a hack.
My guess is hc will get about 20hours and lc will get 25 days or so.
Not using the buck boost regulator is ideal. It should be pretty easy to hack the regulator to let the prop turn it off and have a wake interrupt from buttons.
I have also started a test at 10:45PM CDT. I have removed the zener from a propmod-us_ps_sd and the fuse to the power supply. I have connected the unit to a Duracell DL2032 Hearing aid battery. The unit boots up perfectly on the 3V battery. Now to see how long it will run for. I will check that the unit is running 3 times a day(when I wake up, after work, when i go to bed) until it fails. Will get back to you on the possible run time such a tiny battery can provide. My guess is 12-24 months. Anyone want to place bets on the run time?
Check out my brand new site.
