Product request, Alternate version of existing product (LISY300 gyro)...
Roy Eltham
Currently, you sell a LISY300 module that has a similar form factor to a lot of your other sensor modules (6 pins arranged like a dip chip sticking out of the bottom of the pcb).
However, since the LISY300 can be oriented differently for aligning with different axis, it would be nice if you had an alternate version of the module that had all 6 pins together and sticking out sideways (similar to the say it module). That way you could mount it perpendicular to the host board easily.
I currently have 2 of these modules and in order to mount them perpendicularly I bent 3 of the pins over to the side and then ran short wires from the other 3 pins down to the host pcb. It's not very pretty and is probably opening it up to be affected by signal noise more and causes more signal noise to be generated.
What are the chances of something like this being done?
Check out the Propeller Wiki·and contribute if you can.
