Can a BT dongle be used in a place of a BT modem to hook up to Basic Stamp?
Can I use Bluetooth dongle (which has a USB connector and used with a PC/laptop) in place of Bluetooth Modem to connect it to my microcontroller?
I was just wondering that what's the difference between the two?
The price difference is huge though. The BT modem is about $50 to $60 while I can get the dongle @ less than $5. :-)
Thanx & Regards.
Mind is not a vessel to be filled;
It's a fire to be ignited.
Thanx & Regards.
- Stephen
Sorry to contradict with you, I doubt this is the case.
If a BT dongle can make my laptop communicate with other BT devices (like mobile phone), why I cannot use·a BT dongle·with my BS Stamp or any other microcontroller like Arduino etc to talk to other BT devices.?
I still think that it would be possible but don't know how?
Any thoughts please...
Thanx & regards,
Kashif.
Thanx a lot, you made great sense.
I am planning to use a plug-n-play BT dongle. Since it doesn't require any driver installation, I suppose chances are high that it will work.
Surely, will try it in conjunction with Vinculum, now I know the 'thing' :-) ... great help ... much appreciated.
Warm Regards.
To restate: Your BT dongle cannot be used with just a Stamp. The Stamp is not capable of acting as a USB host for it. A Vinculum chip (like that in the Parallax Memory Stick Datalogger or Vinculum's VMusic2 or VDrive2) can act as a USB host for a Stamp, but whether the Vinculum's built-in drivers can handle your BT dongle is unknown and depend on details of the BT dongle that are generally not provided by the BT dongle's manufacturer.
Recommendation: Don't waste your time. If you just want to learn about USB or BT, there are more productive ways.
I had gotten your point from the previous reply already, but still wanted to try it out, but now thinking of dropping the idea.
Thanx, point taken.
Problems are the "roads" of life,
solutions are only "onramps" to the next problem
············································· "Brad Smith"
