Opening multipe files on SD Card?
Hi all,
I'm trying to read an MP3 off an SD card to play with a VS1033 chip and also log GPS data at the same time. I can play MP3's and I can create/log GPS data, but I can't do them simultaneously currently. I looked into fsrw and do not believe this will do what I need it too. I have been searching everywhere for an answer to this and I have been told to look into DOSonChip, but am wondering if there's a way to do it in software first. Sorry if this is already listed somewhere, my forum searches are producing nothing and my google searches are pointing to all kinds of things. Thanks in advance for any help.
I'd do it a different way. Having a file which is big enough to store the log-data in continuous clusters on the table allows you to write data to the SD card without that overhead. You can have a look at this thread:
http://forums.parallax.com/showthread.php?p=856170
It's a addon for FSRW but it works in parallel. You can use what I called vMem for logging the GPS-data and use the usual FSRW functions for reading the MP3-files. You only have to open the MP3 file. The file for logging is accessed by sector addresses directly. You only have to take care that the address you write to does not get bigger as the size of the swap.sys.
Hope that helps.
