Button PIN 0 INPUT temp VAR LONG IF button = 1 THEN ' Put your code here ENDIF ' Or to assign to a variable temp = button
ADC PIN 7..0 INPUT value VAR LONG value = ADC
Bean
Use BASIC on the Propeller with the speed of assembly language.
PropBASIC thread http://forums.parallax.com/showthread.php?p=867134
March 2010 Nuts and Volts article·http://www.parallax.com/Portals/0/Downloads/docs/cols/nv/prop/col/nvp5.pdf
now I am trying to read P0 thru P7 all at once
like reading the 8 outputs of an ADC. Still no luck, any clues - thanks
Bean
