Introducing Gadget Express GX25A: An open source gadget maker
Tubular
Gadget Express is a simple system for creating and finishing your ideal gadget. It's based on a Propeller "Loco" in the middle, with up to 7 module "cars" coupled to either side. GX25A goes beyond other rapid proto systems by including demo software on every module car, and including metal fascia panels for that truly professional finish.
Here's an example of a GSM based "smart information appliance" (ie pPad)
Features & Benefits.
* Expandable. Connect new modules using a 20 way ganged shunt or other bridge (IDC cable etc)
* Smart. Each module includes an EEprom packed with Obex/demo/cog/status code, and graphic mimic.
* Easy to use. Press the big button to show that module's current status. No programming required to do that.
* Train similarities. Powered by a Propeller "Loco" which can "pull" up to 7 modules on each side.
* Atomic. Each module performs one "atomic" function
* Professional. Laser cut brushed stainless fascias for instant professional finish for industrial applications
* Sustainable. Each module only consumes the resources it needs (pins from the "stack", module length, power)
* Reusable. Disconnect or split modules off and reuse in another design.
* Customizable. Make, share, sell your own module or train of modules using ExpressPCB or OurPCB
* Open Source in this GX25A series. Derived from and compatible with other GX25 series with advanced features
* Compatible with GG's platform using simple adapter to close the gap between P0 and Vss
Post Edited (Tubular) : 3/24/2010 1:03:35 AM GMT
Propeller Forums RSS Feed!
Gadget Gangster - Share your Electronic Projects
The colored square is actually an illuminated 12mm tact button.
Pressing it once brings up the live status page for that module (loads it as an overlay from the 24LC256 eeprom which is under the button)
Pressing it more than that first time cycles through the various operating modes / demo codes for that module
I'm also working on being able to press "chords", of two buttons on different modules, for "cause and effect" style programming.
Timothy D. Swieter, E.I.
www.brilldea.com - Prop Blade, LED Painter, RGB LEDs, 3.0" 16:9 LCD Composite video display, eProto for SunSPOT, PropNET, PolkaDOT-51
www.tdswieter.com
Andrew Williams
WBA Consulting
WBA-TH1M Sensirion SHT11 Module
Special Olympics Polar Bear Plunge, Mar 20, 2010
Andrew, here's the next revision of the prop "loco" which is a smaller footprint (0.9" by 2.5").
I'll get you a schematic shortly as I'm in the process of changing the designs across to ExpressPcb and/or Eagle. Most of the board is "classic prop" except for some extra passives used on the SCL line to detect when the remote buttons are pressed. I might have to sneak a PNP in there, but the external interface pins are fixed.
Andrew Williams
WBA Consulting
www.mikronauts.com E-mail: mikronauts _at_ gmail _dot_ com 5.0" VGA LCD in stock!
Morpheus dual Prop SBC w/ 512KB kit $119.95, Mem+2MB memory/IO kit $89.95, both kits $189.95 SerPlug $9.95
Propteus and Proteus for Propeller prototyping 6.250MHz custom Crystals run Propellers at 100MHz
Las - Large model assembler Largos - upcoming nano operating system
