Shop
OBEX
P1 Docs
P2 Docs
Learn
Events
TV_Termina — Parallax Forums
toggle menu
Categories
Discussions
Sign In
Register
Sign In
Register
Categories
Discussions
Sign In
Register
Home
Propeller 1
TV_Termina
JTC
60
2010-03-23 23:53
edited 2010-03-24 01:14
in
Propeller 1
I am trying to use the TV_Terminal.spin with a base pin of 3 and it comes up on pin 0. What am I doing wrong ?
Jim
Harley
997
2010-03-24 01:00
edited 2010-03-24 01:00
If I recall, the TV_text should be on groups of 4 I/Os. O, 4, 8, 12, etc.
Harley Shanko
JTC
60
2010-03-24 01:12
edited 2010-03-24 01:12
3 pins work fine but I just can't get to work with a basepin of 3. It should be on pins 3,4,5
It comes up on pins 0,1,2
Jim
JTC
60
2010-03-24 01:14
OK I need to read a bit more carefully. You are correct. So if I gave it basepin = 4 it would be OK.
Thanks.... man the little things like that will bit you ever time.
Jim
Sign In
Register
to comment.
Harley Shanko
Jim
Jim
