servo advice needed — Parallax Forums
servo advice needed
mctriviamctrivia Posts: 3,772
edited 2010-03-23 15:05 in General Discussion
I have need for 2 servos as light as possible
servo 1)
120-180 deg motion
able to rotate a mass of 270g with a center of gravity 24mm from the rotation center
servo 2)
360 deg rotation needed but I can gear it if needed.
able to rotate mass of 350g with a center of gravity less then 30mm from the rotation center.
if my math is right then servos with 11oz-in torque or more will do for both. price is not an issue(within reason cheaper is still nice). weight is biggest issue.
any sugestions. or corrections on my mathematical thinking?
24 bit LCD Breakout Board now in. $24.99 has backlight driver and touch sensitive decoder.
If you have not already. Add yourself to the prophead map
