SPI interface H48C Tri-Axis
hi,
i want to use Hitachi H48C Tri-Axis, and it says that it have a SPI interface, but how many bits are if i want to read from this sensor??, 8 bits, 16 bits or 32 bits??
And how do i should interpret this bits received??
thanks
thanks
The links to·what you want are in the bottom right corner.
Check out the Propeller Wiki·and contribute if you can.
