Help with second tone sending — Parallax Forums
scott99scott99 Posts: 14
edited 2010-03-22 19:09 in BASIC Stamp
Hi, My name is Scott, building a clock drive for a telescope. I want to use the bs2 for my frequency controller (using a synchronous drive motor). The program works for the proper sidereal speed but·I need to add a different frequency for lunar tracking.
' {$STAMP BS2}
' {$PBASIC 2.5}
DEBUG "tone sending"
DO
FREQOUT 12, 60000*10000, 1193
LOOP
How do I write the program to have a push button switch to a different frequency output, either on the same pin or a different one?
Desperate in Chicago,
Scott
    Add an IF or CASE statement to choose which commands to run depending on the settings you have. (switch, button, etc.)
    - Stephen
