Need help with Capacitor choice
CannibalRobotics
This may not be the best forum location for this but·I'm building a prop based audio/video control. Part of it is driving IR, some serial and 2x 1 input 6 output line level volume controllers. This section takes a single stereo line level input pair and distributes·them accross 6 independently controlled outputs to amplifiers.
I've settled on the TDA7448 6x6 volume control chip for cost and power supply considerations.
Now the questions.
1) The data sheet application circuit (page 9 of http://www.st.com/stonline/books/pdf/docs/9227.pdf) shows 0.47uF caps on the input and 22uF caps on the output. There is no text in the data sheet on capacitor choices.
For the more expirenced analog guys, what would be the best choice for these capacitors?
2) If I am tying ALL of the inputs to the same source do I need 1 cap or all 6 as shown in the datasheet. My feeling is all six but am I wrong since channel sep is not an issue?
Many thanks,
Jim-
Signature space for rent!
Send $1 to CannibalRobotics.com.
Now the questions.
Many thanks,
Jim-
Leon Heller
Amateur radio callsign: G1HSM
Post Edited (Leon) : 3/21/2010 3:03:22 PM GMT
Quick look at the datasheet and it looks like those caps are just blocking DC. You could probably get away with one cap in your idea but without looking at how the inputs are handled WRT to muted outputs, you might not be able to use this as a 1 to 6 line decoder.
J-
Style and grace : Nil point
Thanks All!
Jim-
The DC output voltage level is 4.5 volts (table 5), and the output capacitors block that from the following stage. Usually the following stage will be biased at zero volts, so the polarity of the electrolytic capacitors is ok. The size of the capacitors can be adjusted if you know the input impedance of the stages that follow. A 22µF capacitor has an impedance of 7 Ω at 1000 Hz. The impedance of the capacitor has to be low with respect to the input impedance that follows, at all frequencies that you want to pass. Is it driving a 600Ω line? The capacitor forms a voltage divider with the input impedance of the following stage. Generally in audio electrolytics are used in preference to tantalums, as electrolytics are more forgiving if they happen to be slightly reversed biased, but you really don't want that to happen!
Tracy Allen
www.emesystems.com
