Seeking Camera Module for Propeller
I'm looking for a camera module for my balancing robot. I want to use it for blobtracking and eventually object recoqnition.
I saw the CMU-cam but that's too expensive. I don't have that amount of money. Are there any other options? I thought about the linescan sensor too but that won't recognize anything else than barcodes.
Any tips are welcome!!
Also i need to order a Gyro to go with my memsic accelerometer. I found this one:
LISY300AL (#SFE08955)
Is this one compatible with the Proppeller? Is there any code available to make it work?
1 Parallax Propeller Robot Control Board
1 Memsic MX2125 accelerometer/ tilt
1 Parallax Ping))) ultrasonic sensor
a few motors and a whole lot of chaos!
Post Edited (Botdocter) : 3/21/2010 12:48:48 PM GMT
Vision processing will be limited by the addressable memory available. If your application requires color then the image that can be stored will be very small. If you plan on processing video in real time then additional memory added through a serial interface will probably be too slow.
Bottom line: Determine what your memory requirements will be before spending time trying to using the Propeller for memory intensive tasks.
