Transmitting video?
Microcontrolled
I have been reading about projects from great Propeller heads from all over the forum and I have not seen this, a way to transmit video from a camera (NTSC) from a robot to a base processor. If you can do this with a Propeller, then great, but if there is something else I need then please tell me, but I am on a very short budget. (As usual) Thanks for the help!
Micro
Don't click on this.....
Use the Propeller icon!!
Micro
I've got one of these cameras on my gate transmitting 60 metres to a Rx and then into a TV capture card on a PC. There was a better picture with this system than with wires.
This sort of thing $28 cgi.ebay.com/Wireless-Mini-CCTV-hidden-Color-Pinhole-Camera-SPY-Cam_W0QQitemZ280480872453QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item414df67805
www.smarthome.viviti.com/propeller
Micro
I haven't tried what you are suggesting, but it might just work. All the 4th pin is doing from the Propeller (When enabled) is sending a subcarrier frequency that mixes with the NTSC video generated from the Propeller. The subcarrier frequency can only span analog TV Channels 2,3,4, and 5 ... I would think, if you generate the correct subcarrier frequency and mix it via the proper resistor divider with a raw (external to the Propeller) Video signal, that you would essentially be doing the same thing (minus the video signal from the Propeller) and have a little video transmitter.
Don't know, I'll have to try it myself.
Beau Schwabe
IC Layout Engineer
