Need a second set of eyes. Pub local variable oddity
Timothy D. Swieter
Attached is an archive of the work I am doing on the Brilldea W5100 driver. Today I made progress on creating the UDP send/receive code. Once I proved the concept I dove into making a more presentable and cleaned up code implementing what I prototyped. That is where the trouble started. In the attached code there is the top file, a Demo file of the W5100 driver and the W5100 driver. The demo is basic, it sets the addresses and initializes the W5100 and the drops into an infinite loop where it receives UDP packets and displays the contents in a serial terminal.
The problem: I can't say for sure what the problem is but it has to deal with local variables or writing to hub ram in an unintentional overwriting manner in one of the W5100 PUBs. Help me find the exact problem.
A clue: In the W5100 driver file you will see PUB rxUDP. You will actually see two lines like this:
I alternately comment each one out. With a bogus local variable inserted, t9, the PUB executes as expected. What is expected is that when the overall demo is loaded the system goes into a waiting state waiting for data to arrive. Because the system just started there are no UDP packets to process. When data arrives it retrieves the packet properly from the W5100 and displays the correct contents.
When the bogus local variable is removed (the second line) it appears that RSR or temp0 is getting clobbered with data or is falsely getting info. What is happening is that the when the demo is first started RSR immediately thinks there is UDP packets to reads and grabs stall, ghost data from the W5100. The driver grabs a few packets and then the whole program goes wonky and eventually causes garbage and maybe even a reboot.
So, what is the cause of the trouble?
Timothy D. Swieter, E.I.
www.brilldea.com - Prop Blade, LED Painter, RGB LEDs, 3.0" LCD Composite video display, eProto for SunSPOT
www.tdswieter.com
PUB rxUDP(_socket, _dataPtr) | temp0, t9, RSR, pcktsize, pcktptr, pcktoffset, pcktstart, rolloverpoint 'This statement works PUB rxUDP(_socket, _dataPtr) | temp0, RSR, pcktsize, pcktptr, pcktoffset, pcktstart, rolloverpoint 'This statement does not work
www.tdswieter.com
if (W5100flags & _Flag_ASMstarted) 'Check if there is data to receive from the W5100 readSPI((_S0_RX_RSR0 + (_socket * $0100)), @temp0, 2) RSR.byte[noparse][[/noparse] 1] := temp0.byte[noparse][[/noparse] 0] RSR.byte[noparse][[/noparse] 0] := temp0.byte[noparse][[/noparse] 1] 'process if there is data if RSR <> 0Local variables (like RSR) are not initialised to zero (like their global relatives). And they always take up a long. In the fragment above you effectively only initialise half of RSR which will give you unexpected side-effects later.
www.tdswieter.com
