Analog sensor on propeller
I need wheel encoders and i came to this idea. I have a mouse with a potentiometer like scrolling sensor. This one doesn't stop at the end of the turn though.
There must be a way to use this as wheel encoders?
I believe it works like this:
everytime the scroll is in default there is no connection. With every click the scroll does, it makes contact on the pieces between the clicks.
The mouse board below uses the same scroll sensor.
1 Parallax Propeller Robot Control Board
1 Memsic MX2125 accelerometer/ tilt
1 Parallax Ping))) ultrasonic sensor
a few motors and a whole lot of chaos!
Keep in mind they are meant for the relatively light use in a mouse and may wear out (mechanically) if put to heavy use on a motor.
Post Edited (kwinn) : 3/20/2010 3:29:19 AM GMT
on every click it closes the switches or opens them.
- Stephen
Just count the clicks.
