using 2 micro dual motor controllers — Parallax Forums
NsanecomXNsanecomX Posts: 22
edited 2010-03-26 20:46 in BASIC Stamp
i have a micro dual motor controller that is trying to control 2 dc motors, but since the motors draw more than one amp each, the first motor works and the other motor shorts out. I cant find a motor with the same specs that draws less than an amp, so would i be able to buy another motor controller place it on the bread board directly behind the one i have now so that the same pins work for both motor controllers but it puts out 2 amps per motor instead of 1. would this work?
thanks in advance for the help
    edited 2010-03-19 20:47
    Sure looks like it, if you have the new version mentioned here.
    Edit: Just re-read your question. Don't just parallel the modules, but wire as shown for 2A capacity per motor per controller.
    Post Edited (erco) : 3/19/2010 11:40:15 PM GMT
    645 x 450 - 51K
  • NsanecomXNsanecomX Posts: 22
    edited 2010-03-26 19:21
    what do you mean?
    if i did parallel them would it ruin them?
    edited 2010-03-26 19:34
    Somebody said...
    You are welcome to try it out and let us know. Why not just do it the way the maker designed it to be done?
    - Stephen
    edited 2010-03-26 19:38
    what do you mean? what way was it designed to be done?
    edited 2010-03-26 19:40
    Jeez, LOOK AT THE PICTURE erco has in his post.
    - Stephen
    edited 2010-03-26 19:44
    i have it set up like that but how would i daisy chain the multiple motor controllers?
    edited 2010-03-26 19:49
    I would start by reading the MANUAL. You can find some help here www.pololu.com/catalog/product/411/resources
    - Stephen
    edited 2010-03-26 20:06
    i guess what i'm trying to ask is if i have 2 motor controllers both set to 2 motor mode (so it sends 1A to each motor), if i put 1 motor controller directly behind the other motor controller on the breadboard and since they're configured the same, would they send 2A total to each motor or do i have to configure each motor controller to 1 motor mode and have them control the 2 motors separately?
    solved never mind.
    the answer to my question if anyone wants it.
    You can place the 2 motor controllers directly behind one another on the breadboard in 2 motor mode and it works. Yes it puts out 2A for each motor now
