Right now we only offer the PCB for the Prop Blade. We have had some trouble with sourcing components in Singapore, but most items are available from on-line companies like Digi-key. We are using the sourcing trouble as motivation to redesign the kit to make it better so we are not investing in kit inventory at the moment. If you want to drive LED Painters you can use just about any Propeller Platform. The connections to the LED Painter are standard I/O interfaces.
This weekend I might get time to scrounge my building material inventory and see if one or two more kits can be put together.
Timothy D. Swieter, E.I. www.brilldea.com - Prop Blade, LED Painter, RGB LEDs, 3.0" LCD Composite video display, eProto for SunSPOT www.tdswieter.com
www.smarthome.viviti.com/propeller
see www.brilldea.com
www.tdswieter.com
www.tdswieter.com
