Prop Package Power
The prop comes in three different packaging. In real world conditions, given all factors relatively the same, is there difference in current drawn by each? i.e. does the smaller package draw less current?
40-Pin DIP Chip
44-Pin QFN Chip
44-Pin QFP Chip
humanoido
40-Pin DIP Chip
44-Pin QFN Chip
44-Pin QFP Chip
humanoido
You only ever need two tools in life. If it moves and it shouldn't use Duct Tape. If it does not move and it should use WD40.
humanoido
is a big difference in the different packages inductance and capacitance.
The dip chips are the worst because of the long lead frames inside them.
The lead less chips are the best because of the short distance from the die
to the board.
Russ
Or is this still negligible?
I'll bet the difference is negligible, but who determines what negligible is?
Rich H
The Simple Servo Tester, a kit from Gadget Gangster.
I don't think that does consume power. Ideal caps/inductors don't consume power and I'm guessing you at least model them as ideal.
Graham
