Forcefully erasing OTP chips...
Is it possible to forcefully erase an old OTP MCU/EPROM? I have an intel 87C42 that I am dying to program, but it's already been loaded with something and it isn't a UV windowed version...
Maybe if you apply 12 volts on pins 1-20 and connect pins 21-40 to ground...
But seriously, is it possible? Has anyone tried?
Quit buying all those fixed voltage regulators, and·get an Adjustable Power Supply·for your projects!· Includes an LED testing terminal!
(no longer new) SD Card Adapter·Now available!· Add extra memory to your next Propeller project with ease!
The only way to remove the charge once it is on the gate is to expose it to ionizing radiation (UV) which will bleed off the charge. I suppose X-rays or gamma rays would also work but I have never been curious enough to try that.
The above statement is not quite accurate. The charge will bleed off very slowly over many years. The original 1702 eproms were notorious for erasing themselves after 10 or more years. The higher the operating temperature the sooner they became blank or partially blank. Some of that may have been due to not being programmed properly in the first place.
You will need the datasheet for your specific part in order to bypass the rom.
-dan
Arguing with myself--sometimes me, myself, and I don't always agree.
(Former) Caterpillar product support technician
www.silabs.com/products/mcu/pages/default.aspx#
Leon Heller
Amateur radio callsign: G1HSM
Post Edited (Leon) : 3/19/2010 2:03:22 PM GMT
I did get a gameboy advance multiboot cable (http://www.ziegler.desaign.de/GBA/gba.htm#Multiboot) that has an Atmel 8051 clone in it, and I'm probably going to take that out and use it for something else.
Also, is there a way to read the program from a 6052 or more specifically, a 6052 variant?
