Propeller development HDL
Does Chip Gracey use gate-level Verilog or RTL Verilog when designing the hardware description for the Props?· I am thinking about delving into my first FPGA project.
Thanks.
Thanks.
Leon Heller
Amateur radio callsign: G1HSM
Post Edited (Leon) : 3/17/2010 7:52:04 PM GMT
I wouldn't follow their example, you'd be better off using VHDL or Verilog.
Leon Heller
Post Edited (Leon) : 3/17/2010 8:20:55 PM GMT
Thanks.
If you aren't debugging at the wavefront timing level (which they probably had to do to perfect the prop design, not to mention that they didn't want to use anybody else's cell libraries and have to fork over cash for them) then just doing your work in 'beh' blocks should probably cut it to get started. Once you get past that then thinking more specifically about the RTL layout of things will be fruitful.
--RvnPhnx
