self-hosted development - what is available? — Parallax Forums
K2K2 Posts: 694
edited 2010-04-15 07:51 in Propeller 1
Fresh off the success of my first-ever Propeller application, I'm still stunned and amazed at how fast it went, how well it worked, how slick it looked, how little it cost, and how much fun it was to do. I take no credit myself - it's due entirely to the fact that 1) Parallax is crazy nuts and 2) a whole lot of great help is available on the Forum.
As a result of this experience, I wonder what the current options are for a self-hosted development system...abandoning the PC entirely. Is there any system available that would enable one to create an application in BASIC, C, SPIN or Propeller Assembly, and burn it to a separate EEPROM/Propeller/crystal/voltage-regulator assembly?
A CP/M machine is pretty interesting. (Brings to memory a guy I knew in Bend, OR that ran a little magazine called Micro Cornucopia that I subscribed to till it went bust.) But I don't suppose it can actually clone portions of itself to another Prop. Is there anything that can?
    edited 2010-03-16 07:58
    Hello David,
    there is something into that direction. I guess there are still some wishes left what sphinx should be able to do,
    I haven't tested it myself. But I think the base is already pretty good.
    http://www.sphinxcompiler.com/
    http://www.cliff.biffle.org/software/propeller/forth/index.php
    and here is ULTIMATE List of Propeller Languages
    (you gonna feel lost if you have read through the entire list)
    best regards
    Stefan
    Post Edited (StefanL38) : 3/16/2010 8:08:02 AM GMT
  • heaterheater Posts: 3,370
    edited 2010-03-16 08:09
    Re: CP/M "But I don't suppose it can actually clone portions of itself to another Prop."
    Depends what you want to do. Under CP/M on the Prop you can create C programs for example. Edit the source with WordStar and compile with BDS C. On the Prop. The resulting executable can be moved to any other CP/M machine, Prop or not. There are many other languages that can be used under CP/M on the Prop.
    Now, if we could get a Spin/PASM compiler written in C that would run under CP/M then it would be able to clone itself it total. If it's possible to compile ADA under CP/M Spin should be a doddle[noparse]:)[/noparse]
    For practical use go with Sphinx. Not that I know how practical that is.
  • lynchajlynchaj Posts: 87
    edited 2010-03-16 11:01
    David Jensen said...
    Hi!· Propeller is wonderful isn't it?
    If you would like to abandon the PC entirely and have a self hosting system you are welcome to check out the N8VEM project.· Using an N8VEM SBC and a PropIO you should be able to completely leave any PC dependence behind.
    The N8VEM SBC is a Z80 computer running CP/M and the PropIO is a board with two Propellers.· The first serves IO for the SBC with PS/2 keyboard, VGA, and microSD.· The second Propeller is unallocated and you can do whatever you would like with it. Both Propellers are accessable by the SBC via an ECB backplane.
    What I would do is take the example PropIO code on the N8VEM wiki and expand it to include reprogramming the Propeller with loadable code.· I am not sure what kind of CP/M development tools are available for generating Propeller code like a PASM or a spin compiler.· I do recall Mike Greene working on a CP/M system for Propeller a while back so maybe he has some ideas.· There are so many Propeller development tools that you probably could find some thing that could be ported to CP/M using BDS C or something like that.
    I would really appreciate it if you would consider the N8VEM system for Propeller development.· I think it would be a great pairing and there is already so much synergy between the Propeller and CP/M systems that it would leverage a lot of work already done to the benefit of all·home brew computer hobbyists.
    Dave (Yoda) has already written a·working·N8VEM SBC ROM image with source code to support PS/2 keyboard and VGA for console IO.· Dave is also working on an updated ROM image to support the microSD for CP/M drive support which I believe is very similar to the existing CP/M microSD support already used by some Propeller projects.
    Good luck with your project.· Thanks and have a nice day!
    Andrew Lynch
    Post Edited (lynchaj) : 3/16/2010 11:12:44 AM GMT
  • BradCBradC Posts: 2,601
    edited 2010-03-16 11:39
    lynchaj said...
    What I would do is take the example PropIO code on the N8VEM wiki and expand it to include reprogramming the Propeller with loadable code. I am not sure what kind of CP/M development tools are available for generating Propeller code like a PASM or a spin compiler. I do recall Mike Greene working on a CP/M system for Propeller a while back so maybe he has some ideas. There are so many Propeller development tools that you probably could find some thing that could be ported to CP/M using BDS C or something like that.
    Hrm... let's take a functional 32 bit compiler and port it to an 8 bit operating system to generate 32 bit code... What?!?
    You only ever need two tools in life. If it moves and it shouldn't use Duct Tape. If it does not move and it should use WD40.
    edited 2010-03-16 12:00
    We already have Z80 & CPM (ZiCog) running on the propeller so why would we want to use a real Z80?
    There is TriBlade, RamBlade and DracBlade. See the links in my signature for TriBlade & RamBlade. DracBlade is near the top of the thread list but is slower than a real Z80 due to the latching.
    SphinxOS & Sphinx is the closest thing to what you are after. There is still some work to do but it does run now. It can compile spin & pasm programs now. All on the propeller. It can launch programs including ZiCog (with the appropriate hardware). See the link in my signature. The Sphinx compiler was written by markp who wrote homespun - the first thirdparty compiler. And we could do with help in developing SphinxOS further.
    What would be nice is to be able to use the development tools such as the wordstar editor in CPM, transfer the file to FAT16, transfer control back to SphinxOS and then compile and run the developed code. Once we have a really good editor under SphinxOS this would not be necessary. However, there are some great programs that run under CPM.
    Shameless Plug... If you want to add a module to an existing prop board, RamBlade should be the obvious choice - size 1.2"x1.9" $40 with complete prop + eeprom + 152KB Sram + microSD and only requires high speed 2 wire serial link to your board plus power (3V3 & Gnd). Sphinx & SphinxOS and ZiCog & CPM already runs on the RamBlade, either self-contained with a mono composite TV connection and PS2 keyboard, or via another prop running a terminal program.
    · Emulators: CPUs Z80 etc; Micros Altair etc;· Terminals·VT100 etc; (Index) ZiCog (Z80) , MoCog (6809)·
    · Prop OS: SphinxOS·, PropDos , PropCmd··· Search the Propeller forums·(uses advanced Google search)
    My cruising website is: ·www.bluemagic.biz·· MultiBlade Props: www.cluso.bluemagic.biz
    edited 2010-03-16 13:08
    Re "Hrm... let's take a functional 32 bit compiler and port it to an 8 bit operating system to generate 32 bit code... What?!?"
    What is wrong with that? *grin*
    Anyway, the Z80 could also be described as a 16 bit micro. And just when you get deep inside pasm and you want to do something really clever with some bit shifts to save some ram driver code and fit it into a cog, the critical instructions turn out not to be 32 bit but 9 bit. Aaargh, this is a fast track path to becoming follicularly challenged!
    I tend to code using the fastest way possible. mbasic still wins after 30 years for testing a couple of quick instructions. Coding C on a PC then compiling on the SIMH and downloading via xmodem is the fastest CP/M way. Coding in C and downloading the raw code and compiling on the board is very close for small programs but not big ones. Catalina is the fastest C environment for the prop I have found. Propbasic is just as sweet. But coding C on the prop and compiling on the prop - the answer is yes, it can be done, but no, it isn't very practical because it is slow and because it involves constantly swapping between wordstar and the bds c compiler.
    What is needed is a text IDE on CP/M. The source code for wordstar but with a compiler built in so you can hit F11 to compile. There is no reason it can't be done, the memory is there, C is portable, but I think it would work out slower.
    The gauntlet has been thrown down "But I don't suppose it can actually clone portions of itself to another Prop. Is there anything that can?"
    Ok, let's allow one small cheat - a pre formatted sd card. Put it into a dracblade with a serial port ready to go. I don't know the serial protocol for programming a prop, but it seems easy to trap with a serial port sniffer. I think the baud rate could be a problem 115k is jolly fast. But assuming we can output at the right baud rate, it ought to be possible to send out data as if it came from a PC. The reset line might have to be hard wired somehow. Can a prop read bits of its own eeprom? I assume so, so a CP/M program ought to be able to read the propellers own eeprom, save that onto sd card, manipulate it if needed, then send it out one byte at a time with the handshaking. Now we have another propeller running all the spin code it needs.
    Next challenge - getting CP/M onto a remote SD card before CP/M is there. That would need some new spin code to grab bytes coming down the serial line and save them to sd card. Possibly an ultra simplified xmodem type protocol and some new spin code. Nothing impossible there as the building blocks already exist in code.
    Repeat the process for some disk drive images. Hmm - 8mb is a big file. Maybe rejig the zicog so it only has one hard drive for the moment and just send one hard drive image.
    Now reboot the propeller and it should load BOOT.DSK and CP/M and the hard drive image. That contains a real copy of xmodem, so future file transfers are a lot easier.
    So I think this is entirely possible. Maybe it would have applications out in the field. I'll think about that some more, as one of the issues I'm working on is how to manage a propeller board in an inaccessable location with only a wireless link. I'm working on a solution where the propeller code doesn't change and is fairly boring and simple, but the CP/M programs are the ones updated and changed. So if the whole thing crashes, you can send simple wireless commands that reset the board but those commands can never alter spin code, they only alter CP/M programs so the spin code stays robust.
    www.smarthome.viviti.com/propeller
    Post Edited (Dr_Acula) : 3/16/2010 1:21:14 PM GMT
  • K2K2 Posts: 694
    edited 2010-03-16 16:59
    I wanted a bunch of stuff to digest and consider, and you've given it to me. smile.gif I'm in the process of studying in detail every product mentioned and every recommendation given. I'd like to identify in my own mind where the weak links are in the quest for easy and natural self-hosting, and picking a task from among them to work on.
    At the same time, it may be worth cogitating (ouch) on possible approaches to the problem from the opposite direction; a sort-of biological approach: Start with implementing a bare bones replication ability and then add adornment and sophistication as opportunities, abilities, and needs suggest themselves.
    btw, I agree that an SD card (or some other non-volatile, re-writable storage) needs to be added to the Prop/EEPROM/crystal/VR basic equipment list unless some crazy hybrid FORTH implementation miraculously saves the day. Even then...
    Post Edited (David Jensen) : 3/16/2010 5:26:58 PM GMT
    edited 2010-03-16 17:16
    Hi!· IMO, an N8VEM SBC plus PropIO suits this requirement ideally.···Since the PropIO has a second Propeller you can use the first Propeller to program (clone) the second and/or use the SBC to directly upload code to either Propeller.· If you are looking for an easy to build system·which uses·DIP and standard 0.1" plated through hole construction (no SMT or tiny parts) it should work well.··N8VEM SBC and associated has the late 1970's/early 1980's design style you'll see in Micro Cornucopia magazine of that era.· Also the Propellers and EEPROMs can be installed in sockets to make swapping components·easy.
    There has been a lot of interest with in the Propeller and Z80 home brew communities with CP/M as a development environment.· Certainly there are the *Blade devices, Mike Greene was investigating something like a Zilog development board (ez80?) at one point, and of course there is the N8VEM system.· I am sure there are many ways to accomplish what you are asking for to include just building your own system from scratch.· Using the N8VEM serial port and/or PropIO microSD would keep the link to your PC if you want it.
    Personally, I recommend a real Z80 CPU as to keep the system as simple as possible.· Placing an emulation layer underneath a development environment·can make debugging a real chore.· As for compatibility IMO·an emulation will never be·as compatible with the real Z80 hardware as an actual Zilog Z80.· In addition, there are hardware tools for the real Z80 that are incredibly powerful like the Nicolet NICE Z80 ICE and the TaunTek Z80 ICE.· I have both and they are wonderful devices.
    http://tauntek.com/Z80-In-Circuit-Emulator.htm
    The one missing piece is the software that James alludes to which is the native CP/M Propeller environment.· In the short term, I would look at the native Propeller development environments like Sphinx or·Forth previously mentioned.· I believe it would be possible and practical to port a free/open source Propeller tool to native CP/M such as a PASM assembler or something similar.· More advanced would be to use BDS C or the like to build an actual spin or similar Propeller IDE.
    All the proposed solutions fit the requirement so really it is a matter of what sort of system you would like to use.· Do you want an all Propeller solution or one that uses vintage style CP/M machine as a Propeller development environment?· Whatever you choose or don't, I wish you the best of luck with your project.· It certainly sounds interesting.
    Andrew Lynch
  • K2K2 Posts: 694
    edited 2010-03-16 18:25
    Andrew, I took a look at your N8VEM this morning for the first time. Wow! Very satisfying. Lots of hooks. Easy to work on. Complete. For a PC replacement, it seems to have just about all the features one could want.
    You are absolutely right: I need to sit down (in my case, go for a hike) and think about what I'm really asking. If one were looking primarily for a PC replacement, your system takes the cake. Conversely, if one selected self-hosting, self-replicating, and simple as his three chief criteria, a PIC or AVR chip with a Forth kernel might be the answer. I guess I'm looking for something in between.
    The video generation abilities of the Prop - where it does such a fabulous job, takes few resources, and plays well with other applications on the same chip - is the single biggest draw for me. I guess that's why I would be looking to stay with the Propeller, whether it was emulating something else or not.
    Also, I'm in love with the multiprocessor paradigm. Miraculous things can be folded into a serial processor like the SX, but it's tedious and exacting work, especially for real-time signal processing. The Propeller is a dream in this regard. I don't think I would be so stunned with the Prop if I hadn't spent so many years grovelling with other architectures.
    So I guess I'd say, initially, that Propeller-based and low-parts-count are two of the more important criteria in my own quest.
    edited 2010-03-17 00:20
    Dr_Acula: Anyway, the Z80 could also be described as a 16 bit micro.
    Um, as cool as ZiCog is I have to disagree with this. The Z80 is pretty solidly 8-bit, having both an 8-bit ALU and an 8-bit path to memory. Nowadays it's the ALU people tend to look at, which is the excuse IBM gave for calling the 8088 16-bit back in the day even though it only had an 8-bit path to memory (and was by all subjective real-world application observations slower than a Z80 running at the same speed).
    In the other direction the 804x and 805x series are considered 4-bit, despite having an 8-bit path to memory, because they have 4-bit ALU's and as a result typically take 30 clock cycles to perform one instruction.
    edited 2010-03-17 01:54
    Yes localroger, I was stirring a bit there, as the Z80 really is 8 bit with some addon 16 bit ops.
    With respect to self replication, CP/M can be recompiled on itself from scratch, but it is much faster to use a cross compiler on a PC, so it is one of those tasks that sounds cool but when you actually have it then you don't really end up using it. I suspect the same might apply to self replicating on the propeller. The big problem I see is getting hold of the source code for a compiler so you could translate it to a language you can run on the propeller - eg spin itself or C or basic. I've never quite worked out what the rules are on that - is it that there is source code available but only to people close to Parallax?
    edited 2010-03-17 02:33
    Dr_Acula said...
    Sphinx comes with complete source.
    edited 2010-03-17 04:32
    BradC: I don't think the source is available for the compiler section. It is in SOB format (compiled modules). Not that this matters.
    edited 2010-03-17 04:48
    Cluso99 said...
  • mparkmpark Posts: 1,332
    edited 2010-03-17 05:56
    Brad is correct. The compiler source files are in the sphinx2 directory. Build instructions are at http://www.sphinxcompiler.com/Home/installation (scroll down to part 6).
    edited 2010-03-17 13:42
    Thanks mpark. I had not realised they were all there. Not that I am going to dig into the compiler stuff anyway.
  • pharseidpharseid Posts: 192
    I noticed Smalltalk on the ultimate language list. I'm assuming this is Smalltalk-80 and was thrown on there as a language that would run under CP/M. Does anyone know if Smalltalk-80 is still available? This would be yet another self-hosting system and with it's own GUI. I'm aware of Squeak, the modern descendent of Smalltalk-80, but that would have memory requirements (and I imagine associated performance issues) that invalidate it as a candidate for the Prop.
    I'm pretty sure I printed out the files on the byte-code interpreter for Smalltalk-80 years ago. If the rest of the files for the system were available, implementing the interpreter in PASM would be an interesting project.
    edited 2010-03-18 11:44
    Hi David!· Thanks!· I think you've got the right idea and should settle on the project requirements first.· There are many legitimate technical solutions but ultimately the best one depends on what you would like to do.··A Propeller based with low part count would tend to favor a *Blade type approach which would work fine.· I recommend·making the development environment to include factors as easy remove and replace of parts such as using ZIF sockets for the EEPROM and Propeller.· One key decision will be what sort of PCB construction technology you would like to use.· Is DIP/PTH a requirement or do you want SMT or a mix?· There are issues with SMT in getting the EEPROM and/or Propeller on and off the board so you might want to carefully consider.· I'd probably recommend a mix of DIP/PTH and SMT if low part count and size are determining factors.· Have you considered a Beagle board?· Possibly a Chameleon AVR or PIC solution?· There are many trade offs to consider.
    There were a couple of points raised in the discussion though I'd like to comment on but don't warrant separate posts; in particular the whole 8 bit versus 16 bit CPU topic is a bit murky and kind of arbitrary.· The Z80 and particularly the 6809 both have 8 bit·external data busses but also have numerous 16 bit internal operations.· The 8080/8085 do also to a lesser extent but all are considered 8 bit CPUs.· However, the 8088 is considered a 16 bit CPU even though it appears to meet (at least·IMO)·the same criteria with 8 bit external data bus and 16 bit internal operations.· Honestly I don't know what the dividing line is but I think it comes down to a general consensus and historical tradition.· There really is no clear line of separation IMO.
    Also, does anyone know what became of Mike Greene's CP/M Propeller development project?· I recall he was working on a tiny ez80 (?) based unit for a stand alone Propeller development kit.· I think it may have been tied to the PDB in some fashion but honestly the details are rather murky.· I am not sure I even remember this correctly. Does anyone recall the project or know what became of it?· Personally I think it would be great to sever the Propeller dependency on PC technology.· I believe the default Propeller IDE·is to use a Windows based PC with the Propeller software although there are many alternatives.· Moving to a self-hosting stand alone Propeller environment makes a lot of sense·to me at least.· Obviously I'd prefer·it with the N8VEM but I think it is a good idea regardless of the implementation.
    Please keep us posted on your progress.· I find this is a very interesting subject.· Thanks and have a nice day!
    Andrew Lynch
  • LeonLeon Posts: 7,620
    edited 2010-03-18 12:05
    localroger said...
    The 8051 (and 8048) has an 8-bit ALU.
    Leon Heller
    Amateur radio callsign: G1HSM
    edited 2010-03-18 16:50
    Andy,
    The Z80 development project got shelved when I got busy with other things and ran into problems interfacing with an SD card from the Z80 board. It's still in a drawer here. It consists of a Propeller Protoboard with a piggyback adapter board for a Zilog eZ80F91A Module. It did work using the eZ80F91A's flash memory for mass storage. There was a floppy used for a work area allocated in the static RAM and two read-only floppies for libraries and executables in the flash memory.
  • K2K2 Posts: 694
    edited 2010-03-18 21:41
    Andrew, I spent four years, early in my career, laying out PC boards. Then I spent another year teaching someone else how to do it so that I didn't have to. At this point in my life, it's almost the last thing I care to do. I'm more than content to buy someone's board. Right now that means the Propeller Proto Board because it's inexpensive, well built, and has sufficient space to mount the few peripherals I plan to add. (If Parallax would make it the Deal of The Day, I'd buy a bunch.) But there are lots of great boards waiting to be tried. smile.gif
    BTW, perhaps the greatest virtue of your system over what I'm proposing is that yours exists! Mine is utter vaporware, so far. But the satisfaction is in the journey.
    The way I figure it, I need to create a simple editor in Spin to execute in one cog while another generates video signals and a third interfaces to the keyboard. A fourth cog would function as the interface to external bulk storage. That's pretty much what I'm working on at the moment. At some point it would be great is if I could figure out how to create Spin tokens and how to transfer the Spin executable in Prop ROM to a cog to interpret those tokens. But I'm not going to worry about all that right now.
    edited 2010-03-18 22:02
    David: SphinxOS has a simple editor, a video generator (3pinTV or my 1pinTV), keyboard (2pin or my 1pin) or it can use a pc as the terminal (but not for the editor program) and a 3-cog SD driver (we will get an option to a 1 or 2 cog solution but using more hub). It runs now and compiles spin and pasm on the prop itself. You should download the Sphinx from mpark for starters as it takes you through compiling "DIR" etc on the prop using a TV and Keyboard.
    If you want to create your own spin tokens you can do that - not a trivial task. However, there is enough info around for you to launch an object using the spin interpreter.
    There was another editor project called "PrEditor" which was a big prop based editor but I do not have a link for this.
    All this will run now on basically any prop hardware with an SD adapter.
  • K2K2 Posts: 694
    edited 2010-03-19 03:25
    Wow! This sound pretty good, Ray. I didn't know it was that far along. I'll download Sphinx and try it out. I probably ought to obtain one of your boards that has an SD interface built in, too.
    edited 2010-03-19 05:44
    For starters, you obviously have a prop board of some kind. It is easy to add an SD card to almost any prop (you need 4 pins). Just buy an SD to microSD converter card for a few $ and solder short wires from the 6 pads to the prop and add pullups. It's an SD card with an internal slot for the microSD card. Just try 1 x 10K to the -CS and it may work good enough. If not add 1 x 10K to the DO pin next. This is a cheap kludge to get you going. The pinouts for the SD are different to the microSD.
  • K2K2 Posts: 694
    "Uniforth" is listed as a language that has been implemented on the Propeller. Where does one go to learn more about it? I have yet to find a thing on it, other than its mention in Humanoido's ultimate language list.
    Cluso99: Thank you! A cheap and very adequate kludge that saved time and dinero.
    localroger: I love your avatar! It reminds me of the actor who played Burke Devlin on Dark Shadows.
