NEW: Universal Adapter for Propeller Platform
Project Page
The Universal Adapter Board (named by microcontrolled!) is a handy little adapter to do stuff like:
- Connect a SpinStudio mainboard to Propeller Platform or Mobo Expansion boards
- Connect a Propeller Platform to SpinStudio or MoBo Expansion boards
- Connect a Propeller Protoboard to MoBo Expansion boards
Note that to use MoBo modules, you'll need a 2x6 2mm pin header (available at Digi-Key). Pull-up SMT Resistors are included, however. An A2D converter (AD7999YRJZ, Digi-Key) that may be necessary for some mobo modules.
The Universal Adapter Board was designed by mctrivia. As usual, let me know if you have any questions!
More info on the project page
Propeller Forums RSS Feed!
Gadget Gangster - Share your Electronic Projects
24 bit LCD Breakout Board now in. $24.99 has backlight driver and touch sensitive decoder.
If you have not already. Add yourself to the prophead map
Quit buying all those fixed voltage regulators, and·get an Adjustable Power Supply·for your projects!· Includes an LED testing terminal!
(no longer new) SD Card Adapter·Now available!· Add extra memory to your next Propeller project with ease!
