How to translate SPIN to PropBASIC — Parallax Forums
caskazcaskaz Posts: 957
edited 2010-03-16 03:24 in Propeller 1
Hi, Guys.
I try to translate from spin to pbas.
But no good.
I want your sdvise, please.
And pbas is more complex than spin.
Can does sin.pbas modify more simple?
sin.spin
CON
  _clkmode = xtal1 + pll16x
  _xinfreq = 5_000_000
PUB main | sine, degree, dT, T, w
  sine := $e000
  ctra := %00110 << 26 +  0
  dira[noparse][[/noparse]0] := 1
  dT := clkfreq/10000   '10770
  T := cnt
  repeat
    repeat degree from 0 to 8190   ' [noparse][[/noparse]0 - 360]degree
      w := $7ff & degree
      case degree & $1000
        0:                    '1st or 2nd quadrant
          case degree & $800
            0:
              frqa :=  word[noparse][[/noparse]sine + (w << 1)] << 15 + $7fffffff       '1st quadrant
            other:
              frqa :=  word[noparse][[/noparse]$f001 - (w << 1)] << 15 + $7fffffff      '2nd quadrant'
        other:
          case degree & $800
            0:
              frqa :=  -(word[noparse][[/noparse]sine + (w << 1)] << 15) + $7fffffff    '3rd quadrant
            other:
              frqa :=  -(word[noparse][[/noparse]$f001 - (w << 1)] << 15) + $7fffffff   '4th quadrant
      waitcnt(T += dT)
sin.pbas
DEVICE          P8X32A, XTAL1, PLL16X
XIN             5_000_000
top  con  $e000
bottom    con  $f001
P0   pin  0 output
wave var  long
dT   var  long
T    var  long
degree    var  long
w    var  long
addr var  long
data1     var long
data2     var long
check1     var long
check2     var long
sin_data1 var  long
sin_data2 var  long
sin      func 3
Start:
  ' user start-up code
     countera 48,P0
     dT = 80_000_000/10000
     T = cnt
Main:
  ' Main program code goes here
     do
          for degree = 1 to 8190
               w = $7ff & degree
               check1 = degree & $1000
               check2 = degree & $800
               sin_data1 = sin top, w, 1
               sin_data2 = sin bottom, w, 0
               if check1 = 0 then
                    if check2 = 0 then
                         frqa = sin_data1 << 15 + $7fffffff  <--- error INVALID NUMBER OF PARAMETERS"        "
                    else
                         frqa = sin_data2 << 15 + $7fffffff  <--- error INVALID NUMBER OF PARAMETERS"        "
                    endif
               else
                    if check2 = 0 then
                         frqa =  -(sin_data1 << 15) + $7fffffff  <--- error INVALID NUMBER OF PARAMETERS"        "
                    else
                         frqa =  -(sin_data2 << 15) + $7fffffff  <--- error INVALID NUMBER OF PARAMETERS"        "
                    endif
               endif
               waitcnt T,dt
          next
     loop
  GOTO Main
  END
func sin
     getaddr __param1, addr  <--- error INVALID "PARAMETERS"
     if __param3 = 1 then
          addr = addr + (__param2 << 1)  <--- error INVALID NUMBER OF PARAMETERS"    "
     else
          addr = addr - (__param2 << 1)  <--- error INVALID NUMBER OF PARAMETERS"    "
     endif
     rdword addr, data1
     return data1
     endfunc
Post Edited (caskaz) : 3/14/2010 11:54:19 AM GMT
  • Christof Eb.Christof Eb. Posts: 1,495
    edited 2010-03-14 12:59
    you can do only one operation in one line.
    not: a= a+b+c
    but: a=a+b (or: inc a,b)
    inc a,c
    Have fun, Christof
  • caskazcaskaz Posts: 957
    edited 2010-03-14 13:11
    Thnks.
    I modified.
    frqa = frqa + $7fffffff
    I deleted 4 erros.
    There are still 3 erro of "func sin."
    edited 2010-03-16 03:00
    Hi, Guys.
    It works.
    But after about 53seconds, sin-wave is output on P0(RC cuicuit out).
    Why after about 53seconds?
    Where is incorrect code?
    XIN             5_000_000
    top  con  $e000
    bottom    con  $f001
    P0   pin  0 output
    dT   var  long
    T    var  long
    degree    var  long
    w    var  long
    addr var  long
    read_data     var long
    check1     var long
    check2     var long
    sin_data var  long
    sin      func 3
    Start:
         countera 48,P0
         dT = 80_000_000/500000
         T = cnt
    Main:
         do
                   w = $7ff & degree
                   if check1 = 0 then
                        if check2 = 0 then
                             sin_data = sin top, w, 1
                             frqa = sin_data + $7fffffff
                        else
                             sin_data = sin bottom, w, 0
                        endif
                   else
                        if check2 = 0 then
                             frqa =  -sin_data + $7fffffff
                        else
                        endif
                   endif
                   waitcnt T,dt
              next
         loop
      GOTO Main
      END
    func sin
              __param2 = __param2 << 1
              addr = __param1 + __param2
         else
              addr = __param1 - __param2
         endif
         rdword addr, read_data
         read_data = read_data << 15
         return read_data
         endfunc
    It takes about 16msec on 1-cycle. When dT exceed 160ticks,sin-wave don't output.
    In case of SPIN, it takes about 800msec on 1-cycle.
    In case of assembler, it takkes about 9msec on 1-cycle.
    PropBASIC is fast.
    edited 2010-03-16 03:09
    The 53 second wait is because you set T to cnt, then later wait for that value to appear in the system clock (waitcnt T,dt). By the time the waitcnt occurs, quite a bit of time passes by and the system clock is several 100 nanoseconds beyond the value in T. The waitcnt forces the cog to wait for the 32 bit system clock to roll over. Solution is to add a few 100 to the initial value in T. You can look at the execution time of the code in the loop and use that plus a small "fudge factor" if you want something more exact.
    Thanks, Mike.
    I changed to "T = cnt + dT".
    It fine works.
