IBM launches 4yr study in cooling methods for 3D processors — Parallax Forums
HollyMinkowskiHollyMinkowski Posts: 1,398
edited 2010-03-19 18:55 in General Discussion
This is what will allow Moore's law to continue into the 2020s
www.zurich.ibm.com/news/10/moore.html
Probably the first processors capable of modeling the human brain will be 3D cpu's with liquid pore cooling.
article says said...
Unlike current processors, the CMOSAIC project considers a 3D stack-architecture of multiple cores with a interconnect density from 100 to 10,000 connections per millimeter square. Researchers believe that these tiny connections and the use of hair-thin, liquid cooling microchannels measuring only 50 microns in diameter between the active chips are the missing links to achieving high-performance computing with future 3D chip stacks.
    edited 2010-03-17 14:42
    Ahh yes the joys of CPU cooling .
    and I thought my Liquid CO2 AMD K6-2 450Mhz bumped to 550 was da bomb back when I was young( back when there was jumpers !! on MoBoards) .
    I still have that system ,Mind it is now normal again as a server.
    IBM all-was does some cool (bad pun) stuff with computers and there Chips like POWER 7 .
    I do see one HUGE issue .. Those cooling paths are so small that a dust particle could block them .
    unlike our current Water glycol cooling systems you can buy online this system is not for a end user to tinker with ..
    Peter KG6LSE
    "Carpe Ducktum" "seize the tape!!"
    peterthethinker.com/tesla/Venom/Venom.html
    Never underestimate the bandwidth of a station wagon full of tapes hurtling down the highway. —Tanenbaum, Andrew S.
    LOL
  • StarManStarMan Posts: 306
    edited 2010-03-18 02:21
    It's·gonna take some real strategery to make that condensator work in such a small package.· I want to meet the designer.
    edited 2010-03-19 15:13
    If they approach cooling as has been done in the past, the failure problems will be the same. Dust accumulation is by and far the biggest issue. I clean my computers at least once a year by complete disassembly and dust removal.
    Here in Taiwan, a laptop needs to operate in a dusty outdoor cafe at 95 degrees F WITH 95% HUMIDITY. It seems almost everyone has been overly optimistic and ignored what high humidity does to the efficiency of heat sinks and surface areas. So laptops made for the US are not reliable in such environments.
    The best way to cool your PC is to buy a small bar refrigerator, drill a hole for cables in the side (that usually is just sheet metal and insulation). And then, keep the darned thing at about 40 degrees F. At that temperature, the humidity factor drops out. Hopefully, it won't take IBM 4 years to figure this out. A good second best to dehumidify so that the cooling fins can cool effectively. But it is really awkward to dehumidify without droping the temperature - almost silly.
    In sum, we are going back to chilled main frames and air conditioned buildings. Nothing new here.
    Ain't gadetry a wonderful thing?
    aka G. Herzog [noparse][[/noparse] 黃鶴 ] in Taiwan
    Post Edited (Loopy Byteloose) : 3/19/2010 3:18:46 PM GMT
    edited 2010-03-19 16:20
    Holly: Haven't seen you around for a while... What have you been up to?
    · Emulators: CPUs Z80 etc; Micros Altair etc;· Terminals·VT100 etc; (Index) ZiCog (Z80) , MoCog (6809)·
    · Prop OS: SphinxOS·, PropDos , PropCmd··· Search the Propeller forums·(uses advanced Google search)
    My cruising website is: ·www.bluemagic.biz·· MultiBlade Props: www.cluso.bluemagic.biz
    edited 2010-03-19 17:30
    MEMS and Piezo might be a simple way to pump the refrigerant around ...
    Peter KG6LSE
    LOL
  • bill190bill190 Posts: 769
    edited 2010-03-19 17:36
    I wonder what modern technology can do for a refrigerant compressor / pump?
    General Motors vehicles use a very simple air conditioning system called CCOT.
    There is just a tiny orifice which restricts the flow of refrigerant. Something similar would fit into a small space.
    So it seems to me the pump / compressor would be the only question...
    @Cluso99
    I have been busy writing a lot of code.
    pattern analysis stuff. It's enough to give you a nervous breakdown.
    It's just not that easy to get a processor to see a pattern in a bunch of data
    that anyone can easily see if it is displayed on a monitor. It reminds you
    just how stupid even a fast processor is (or maybe it's just how stupid we programmers are)
