6.25 MHz resonator and FullDuplexSerialPlus
Has anyone used the new 6.25 MHz resonator with "FullDuplexSerialPlus"?
I used the crystal this way:
CON
_clkmode = xtal1 + pll16x
_xinfreq = 6_250_000
when I have my top object send data to the Terminal the display is garbage!
Can anyone help me?
Stan
CON
Can anyone help me?
Stan
JMH
Crystal.
Jon McPhalen
Hollywood, CA
· Emulators: CPUs Z80 etc; Micros Altair etc;· Terminals·VT100 etc; (Index) ZiCog (Z80) , MoCog (6809)·
· Prop OS: SphinxOS·, PropDos , PropCmd··· Search the Propeller forums·(uses advanced Google search)
My cruising website is: ·www.bluemagic.biz·· MultiBlade Props: www.cluso.bluemagic.biz
Would you not have thought that I would have double check it the most obvious!! The baud rate setup between the top object and the Terminal???
Well stupid is as stupid does....
My thanks to you all for all of your responses. From those responses the light came on and the right cluster of neurons fired.
Stan
no truer words were ever written!
Thanks, again!
