(Untitled)
Has anyone used the new 6.25 MHz resonator with "FullDuplexSerialPlus"?
I used the crystal this way:
CON
_clkmode = xtal1 + pll16x
_xinfreq = 6_250_000
when I have my top object send data to the Terminal the display is garbage!
Can anyone help me?
Stan
CON
Can anyone help me?
Stan
Or perhaps there is a hard-wired assumption for 80MHz timing somewhere?
(fyi, you are not supposed to double-post)
www.mikronauts.com E-mail: mikronauts _at_ gmail _dot_ com 5.0" VGA LCD in stock!
Morpheus dual Prop SBC w/ 512KB kit $119.95, Mem+2MB memory/IO kit $89.95, both kits $189.95 SerPlug $9.95
Propteus and Proteus for Propeller prototyping 6.250MHz custom Crystals run Propellers at 100MHz
Las - Large model assembler Largos - upcoming nano operating system
No other object is including _clkmode or _xinfreq.
Have you or anyone else used the 6.25 crystal with the object "FullDuplexSerialPlus"?
Stan
